Page 2 of 3 1 2 3
Re: 572 Vacum Pump [Re: Raffaplymouth60] #2625769
02/25/19 06:55 AM
02/25/19 06:55 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Where is your Vac regulator mounted?
Re: 572 Vacum Pump [Re: Raffaplymouth60] #2625850
02/25/19 02:12 PM
02/25/19 02:12 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You likely don't NEED a regulator as it will never pull enough to hurt anything. Just my .02
Re: 572 Vacum Pump [Re: Raffaplymouth60] #2625942
02/25/19 05:27 PM
02/25/19 05:27 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I first mounted mine in the Indy valley tray. It filled my catch can on the first dyno pull even with a Morose 22635 positive seal vented fitting. I moved it to the valve cover and after 17 pulls it barely had anything in the catch can.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 572 Vacum Pump [Re: Al_Alguire] #2625949
02/25/19 05:44 PM
02/25/19 05:44 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I heard that anything over 12in/Hg was too much on a wet sump. I had to adjust mine to get under that using a 4 vane Moroso BTW.
I've seen folk mount the reg on the opposite rocker cover to the take off, this way there is an air flow through the engine and you will pull oil through.
Re: 572 Vacum Pump [Re: Tig] #2626125
02/26/19 12:02 AM
02/26/19 12:02 AM
Originally Posted By Tig
[quote=Al_Alguire]
This is exactly what GZ says to NOT DO, don't suck outside dirty air across the motor tsk
I've heard and know racers that shoot for 17.0 inches at the starting line with a regular wet sump oil system shruggy
I get barely 5.0 inches with my current GZ pump in neutral revved up whiney
The next motor will have the Moroso 4 vane pump on it and I'll do every thing I can to seal it up so it holds a vacuum luck
Re: 572 Vacum Pump [Re: Cab_Burge] #2626244
02/26/19 11:30 AM
02/26/19 11:30 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
I started off w/ an Aerospace vacuum pump kit which is a total piece of crap. Had 2 pumps fail and the mandrel is junk too. Never pulled more than about 6-7" w/ the regulator closed.
The regulator is mounted on the intake side of the pump itself.
I switched to a Moroso 4 vane pump and CV products mandrel drive setup and couldn't be happier. It pulls 10" at half throttle where it is set right now...honestly not sure what it pulls at WOT.
Mine pulls from the driver's side valve cover w/ no baffle at all. No issue pulling too much oil. I drain it after I get home from the track.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 572 Vacum Pump [Re: an8sec70cuda] #2626402
02/26/19 05:37 PM
02/26/19 05:37 PM
Italy
Raffaplymouth60 Offline OP
Italy
OMG i don't have this valve , i see in your pictures on my vacuum pump !
1970 Cuda 496 street driven 9.22@150
1971 Demon 572 7.82@176
1957 Desoto Adventurer Convertible 345 Hemi
1958 Plymouth Fury Christine
2008 Dodge Ram 1500 Hemi
1970 Dodge ChallengerRT 6pack 4 speed 1 of 135
1968 Dodge Charger RT 4 speed
Re: 572 Vacum Pump [Re: Raffaplymouth60] #2626404
02/26/19 05:53 PM
02/26/19 05:53 PM
Do you have a gauge on the car so you can see how much vacuum it's pulling?
Put the line on the valve cover first. You may not need a regulator at all depending on how much it pulls.
CHIP
Re: 572 Vacum Pump [Re: Raffaplymouth60] #2626409
02/26/19 06:03 PM
02/26/19 06:03 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have the same reg as pictured on my Hemi also. I only picked up about 8 hp with the pump and mine also make 10in of vac. But that was mainly due to that I run an old school std tension 1/16, 1/16, 3/16 ring pack due to being a street car. Others results will vary from engine to engine.
Re: 572 Vacum Pump [Re: 6PKRTSE] #2626413
02/26/19 06:11 PM
02/26/19 06:11 PM
Italy
Italy
Nice !
Re: 572 Vacum Pump [Re: an8sec70cuda] #2626414
02/26/19 06:12 PM
02/26/19 06:12 PM
Italy
Italy
bought now on Summitracing !
Re: 572 Vacum Pump [Re: Raffaplymouth60] #2626416
02/26/19 06:13 PM
02/26/19 06:13 PM
Italy
Italy
look like don't touch the Rocker arms
Re: 572 Vacum Pump [Re: Al_Alguire] #2626417
02/26/19 06:16 PM
02/26/19 06:16 PM
Italy
Italy
If hood clearance is an issue you can put it on the inside portion of the valve cover between rocker arms possibly. Not sure what head and rocker set up you have but its worth looking at. Along with the Moroso baffle you should be way better. UNLESS you have an external leak.
nice information
Re: 572 Vacum Pump [Re: Raffaplymouth60] #2626683
02/27/19 12:09 PM
02/27/19 12:09 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Put one of these back where you had the pick up fitting.....
https://www.moroso.com/pub/media/instructions/22636_instweb.pdf
You shouldnt have any with that Valve cover Mounting. Should work good their.
My need to add a deflector later if needed.
Just my 2 cents.
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: 572 Vacum Pump [Re: Raffaplymouth60] #2626823
02/27/19 06:45 PM
02/27/19 06:45 PM
Italy
Italy
i have installed in the left cover .. will let you know if are ok !
Re: 572 Vacum Pump [Re: Raffaplymouth60] #2627563
03/01/19 03:16 PM
03/01/19 03:16 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The engine in the Cuda went 404 passes at its last freshen up. It pulls 16-17" of vacuum and there has NEWVER been an issue with the pins period. That was freshen up number 2 on those pins and pistons, they had a total of 782 laps on them since new when I sold it. Still at 16-17" of vacuum, never an issue
In the heads up car we pull 20-21" each pass. Engine comes out every year. Never an issue with pins or pistons. Both ran 4 vane enhanced Moroso pumps and both are wet sumps. Just stating my EXPERIENCE not speculation.
Re: 572 Vacum Pump [Re: Al_Alguire] #2627620
03/01/19 06:13 PM
03/01/19 06:13 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Good to know up Every days a school day smile
Re: 572 Vacum Pump [Re: Raffaplymouth60] #2627637
03/01/19 06:46 PM
03/01/19 06:46 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
What heads are on this engine and how many quarts of oil are you running in what oil pan? Also, was the engine run on a dyno, and if so, did it fill the oil tank there? I used to pull 14+" of vacuum on my B1 motor, from the valley pan. It had a small baffle on it though.
Re: 572 Vacum Pump [Re: Raffaplymouth60] #2628000
03/02/19 06:34 PM
03/02/19 06:34 PM
Italy
Italy
hello ! news is : installed relief valve and i have relocated the puller in the left cover i would know how quantity of oil can suck in 10 second at 7000 rpm ? i have installed also the vacuum gauge .. and at max RPM i read 10 of vacuum
Re: 572 Vacum Pump [Re: Raffaplymouth60] #2628010
03/02/19 07:00 PM
03/02/19 07:00 PM
Italy
Italy
handsome japanese boy names is 50 ML around 2 OZ
Page 2 of 3 1 2 3
