Re: Vanke Intake modifications
[Re: A727Tflite]
#2626669
02/27/19 11:26 AM
02/27/19 11:26 AM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
https://board.moparts.org/ubbthreads/upload2/5671605-Vankemod.jpgI don't have any jetting recommendations. I have one here, but I haven't built the motor yet.
[Re: A727Tflite]
#2626684
02/27/19 12:10 PM
02/27/19 12:10 PM
Posts: 4,206 New York
polyspheric
New York
Can't answer your request, but the manifold is an answer to "what can I do for more peak power, if I'm limited to the original factory casting?". I would expect weird mixture distribution, less stable idle, more pump shot needed.
Boffin Emeritus
[Re: A727Tflite]
#2626693
02/27/19 12:37 PM
02/27/19 12:37 PM
Posts: 2,631 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I believe there is an old Direct Connection publication on jetting for those. (Possibly a print also.) Of course it will matter if you are using normal street hemi carbs or the 4345S/4346S that came on them. If you go look at a real one you can draw your own print. It is simple machining and welding a dam in. Make sure it's a real one you're looking at not one of those god awful jobs that some hack did.
2011 Drag Pak Challenger
[Re: A727Tflite]
#2626750
02/27/19 03:32 PM
02/27/19 03:32 PM
Posts: 25,741 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The factory carb mod kit for the Vanke intake was P2836137.
[Re: A727Tflite]
#2626777
02/27/19 04:40 PM
02/27/19 04:40 PM
Posts: 7,477 Minnesota
Hemi_Joel
Minnesota
From experience I can tell you, a stroker motor cures any deficiencies in low-end or idle that may have been caused by a Vanke intake modification. My 474 Hemi with a Vanke intake torques out like a locomotive and pulls hard over 7000 RPM. that's not to say that there aren't better choices for an intake, like the stage 5, but if you need to use the stock casting, the Vanke mod is a good start
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: A727Tflite]
#2626806
02/27/19 05:31 PM
02/27/19 05:31 PM
polyspheric
New York
Partially removing the divider wall makes each bank draw from both left & right sides of both carburetors (the reverse of why 180° manifolds are used). Vacuum signal is reduced, not with this design but any wall height reduction. Since the manifold itself does not have equal air flow to each port (unavoidable with dual-plane manifolds - read some of Vizard's tests showing as much as 50 CFM difference between high and low) even the original fuel distribution is now gone. The WOT can be made closer by stagger jetting, front-rear bias, HSAB experiments, but not the A:F balance to each cylinder.
Boffin Emeritus
[Re: A727Tflite]
#2626810
02/27/19 05:42 PM
02/27/19 05:42 PM
polyspheric
New York
Thanks, John - I suspect a larger photo would show asymmetrical booster venturi notches biasing emulsion discharge off center?
Boffin Emeritus
[Re: A727Tflite]
#2626981
02/28/19 02:44 AM
02/28/19 02:44 AM
Posts: 3,069 Michigan
A727Tflite
Booster throats are all equal in size. No sniveys or notches in any of them.
[Re: lewtot184]
#2627049
02/28/19 12:31 PM
02/28/19 12:31 PM
an8sec70cuda
stroker/manual; i'd definitely try bigger than stock carbs. The Vanke manifold I have is going on a mild 540" street motor w/ a 4 speed behind it. Have an older pair of Carter comp 750s for it.
[Re: A727Tflite]
#2627096
02/28/19 02:20 PM
02/28/19 02:20 PM
Posts: 1,696 central il.
second 70
central il.
Here is a picture of the KB marine intake. The mods are similar to the Vanke but have the bases farther apart so you can use Holleys.
[Re: A727Tflite]
#2627153
02/28/19 04:35 PM
02/28/19 04:35 PM
Posts: 5,106 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
I use to have some Dyno pull information from years ago and will see if I can dig them up but never went that way so likely it went into garbage. Also believe NHOA had put in their News Letter in the 80s the jetting used when going from a stock intake to a modified Vank intake and I believe it was on a stock motor. This is what I can remember from the dyno test on intakes. Gain from stock to Vank was around 40 HP and then using the Stage V intake it gained about 75 HP. I can not remember what changes were used for carbs and even how much if any modifications the Hemi Motor had.
1971 HEMI E BODY REGISTRY
[Re: A727Tflite]
#2627228
02/28/19 08:39 PM
02/28/19 08:39 PM
polyspheric
New York
That's some precision machining there, Bubba. There's actual math for "how much less does an orifice flow if the entry is a sharp-enough-to-shave-with edge?", and it's not good.
Boffin Emeritus
[Re: A727Tflite]
#2627376
03/01/19 02:11 AM
03/01/19 02:11 AM
rickseeman
Stuttgart, Arkansas
OT but FYI I had a pair of Holleys for the KB Marine intake once. In case anybody is wondering I believe the numbers are 4127/4128. Mine were built by Bauman I believe, based on the handwriting. They were made from 3116 carbs. I wish I would have put that intake and carbs on something and drove it. Someone later told me not to use staged linkage with those. Have both primaries open together. I asked KB once how many of those intakes he made. He said he didn't remember for sure, maybe 75. Just passing on the info.
[Re: polyspheric]
#2627406
03/01/19 08:46 AM
03/01/19 08:46 AM
Posts: 6,389 nielsville, minn.
quickd100
nielsville, minn.
That's some precision machining there, Bubba. There's actual math for "how much less does an orifice flow if the entry is a sharp-enough-to-shave-with edge?", and it's not good. I was looking at the picture and also thinking why didn't they radius and blend it.
