hard brake pedal and cant get the back brakes to bleed. #2626476
02/26/19 08:55 PM
02/26/19 08:55 PM
las vegas,nv
mopar muscle7271 Offline OP
las vegas,nv
I have no back brakes on my 71 dart.non brake booster car.I got one of those brake vacuum bleeder kits.still couldnt no fluid to come out of bleeder.tried havin someone pump the brake pedal still nothing.the brake pedal is very stiff i have a new brake master cylinder on and lines.what could it be?
Re: hard brake pedal and cant get the back brakes to bleed. [Re: mopar muscle7271] #2626480
02/26/19 09:01 PM
02/26/19 09:01 PM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
did you bleed the master before install? is it a disc or drum brake car? there are different masters for them one has a larger piston and one is smaller on manual brakes the diference will affect pedal feel. i have also have blocked lines and distribution blocks before.
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: hard brake pedal and cant get the back brakes to bleed. [Re: mopar muscle7271] #2626481
02/26/19 09:05 PM
02/26/19 09:05 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
First thing is are you getting pressure out of both master cylinder ports? If you are then work your way from there back to the rear brakes to see where the stoppage is. If not be sure the rod from the pedal to the MC is adjusted right. Has this always been a manual brake car?
Re: hard brake pedal and cant get the back brakes to bleed. [Re: aspenrt360] #2626483
02/26/19 09:10 PM
02/26/19 09:10 PM
las vegas,nv
las vegas,nv
I had a shop put in while it was gettin painted,redid lines to.car was always a manual brake car.disc in front and drum in rear.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: mopar muscle7271] #2626486
02/26/19 09:16 PM
02/26/19 09:16 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Seems if the shop put it in then they should make it work correctly.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: mopar muscle7271] #2626490
02/26/19 09:26 PM
02/26/19 09:26 PM
las vegas,nv
las vegas,nv
Definitely right on that,they didn't.though they just needed to bleed.seems to be more than that now.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: mopar muscle7271] #2626494
02/26/19 09:29 PM
02/26/19 09:29 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Like I said start at the master cylinder and work your way back.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: mopar muscle7271] #2626514
02/26/19 10:16 PM
02/26/19 10:16 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
sounds like the safety shuttle is tripped.
Don't be the exception.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: mopar muscle7271] #2626576
02/27/19 01:01 AM
02/27/19 01:01 AM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
replace the rear center hose attached to the rear end
Re: hard brake pedal and cant get the back brakes to bleed. [Re: mopar muscle7271] #2626583
02/27/19 01:24 AM
02/27/19 01:24 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Before you replace anything I would crack fittings and see if you have flow. Either work from teh MC back or from the rear brakes forward, you will need a helper to work the pedal.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: Supercuda] #2626593
02/27/19 01:48 AM
02/27/19 01:48 AM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
his first post eluded to cracking the fittings, unless i didnt read correctly.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: mopar muscle7271] #2626636
02/27/19 07:39 AM
02/27/19 07:39 AM
Southeast Ohio
Big Block 69 Offline
Southeast Ohio
My car has seemingly had this same issue. For my car, it was the rubber hose that fed the rear axle that had collapsed internally and needed replaced.
Rick
69 Super Bee 440 Sixpak. 11.60s.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: Big Block 69] #2626644
02/27/19 09:34 AM
02/27/19 09:34 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Rick
When I bought my 69 cuda I replaced the master cylinder, wheel cylinders (swapped the 7 1/4 rear for a 8 3/4). I bleed the front just fine, but could not get the back bleed. I tried the hand pumps, someone pumping the pedal etc. It ended up being the hose that connects to the rear.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: jcastle1] #2626652
02/27/19 10:01 AM
02/27/19 10:01 AM
las vegas,nv
las vegas,nv
I cracked the bleeders open and nothing from each one.brake pedal is so dam stiff u could hardly pump it.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: jcastle1] #2626653
02/27/19 10:04 AM
02/27/19 10:04 AM
las vegas,nv
las vegas,nv
If your talkin about the black rubber one,its been replaced.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: mopar muscle7271] #2626661
02/27/19 10:30 AM
02/27/19 10:30 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
New doesn't always mean that it's good.
As has been stated, start at the back and crack the lines loose and work your way forward to a point that you get fluid coming out.
It's either a blockage or a brake valve problem.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: mopar muscle7271] #2626666
02/27/19 11:20 AM
02/27/19 11:20 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
the bleeders are at the end of the line. You have the connection where the hose connects tot eh body hard line. crack it there and see if you get anything. If not, the hard line connects tot eh combination valve, crack the fitting there and see if you get anything. The combination valve is fed from the M/C, crack the fitting there and see if you get anything.
the problem will lay between the first leaking connection and the last one that didn't leak. If nothing comes out of the M/C that is your issue.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: mopar muscle7271] #2626678
02/27/19 11:50 AM
02/27/19 11:50 AM
Mass
charge70 Offline
charge70  Offline
Mass
Get a helper and start bleeding brake lines.Start at the master and work from there.When you stop getting fluid flow,you found the problem.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: charge70] #2626754
02/27/19 03:43 PM
02/27/19 03:43 PM
As said; grab a helper to work the pedal & you starting at the MC.
Re: hard brake pedal and cant get the back brakes to bleed. [Re: RapidRobert] #2627446
03/01/19 11:56 AM
03/01/19 11:56 AM
Berwyn, IL
challenger70 Offline
Berwyn, IL
If you don't have a helper I have found these and a little catch can to be perfect for doing it alone.
http://www.russellperformance.com/mc/speed-bleeders/
