hard brake pedal and cant get the back brakes to bleed.
#2626476
02/26/19 08:55 PM
02/26/19 08:55 PM
Posts: 459 las vegas,nv
mopar muscle7271
las vegas,nv
I have no back brakes on my 71 dart.non brake booster car.I got one of those brake vacuum bleeder kits.still couldnt no fluid to come out of bleeder.tried havin someone pump the brake pedal still nothing.the brake pedal is very stiff i have a new brake master cylinder on and lines.what could it be?
Re: hard brake pedal and cant get the back brakes to bleed.
[Re: mopar muscle7271]
#2626480
02/26/19 09:01 PM
02/26/19 09:01 PM
Posts: 855 ontario canada kingston
aspenrt360
did you bleed the master before install? is it a disc or drum brake car? there are different masters for them one has a larger piston and one is smaller on manual brakes the diference will affect pedal feel. i have also have blocked lines and distribution blocks before.
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
#2626583
02/27/19 01:24 AM
02/27/19 01:24 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Before you replace anything I would crack fittings and see if you have flow. Either work from teh MC back or from the rear brakes forward, you will need a helper to work the pedal.
#2626636
02/27/19 07:39 AM
02/27/19 07:39 AM
Posts: 10 Southeast Ohio
Big Block 69
Southeast Ohio
My car has seemingly had this same issue. For my car, it was the rubber hose that fed the rear axle that had collapsed internally and needed replaced.
Rick
69 Super Bee 440 Sixpak. 11.60s.
[Re: Big Block 69]
#2626644
02/27/19 09:34 AM
02/27/19 09:34 AM
Posts: 1,774 Keymar, MD
DusterKid
Keymar, MD
Rick When I bought my 69 cuda I replaced the master cylinder, wheel cylinders (swapped the 7 1/4 rear for a 8 3/4). I bleed the front just fine, but could not get the back bleed. I tried the hand pumps, someone pumping the pedal etc. It ended up being the hose that connects to the rear.
[Re: jcastle1]
#2626652
02/27/19 10:01 AM
02/27/19 10:01 AM
mopar muscle7271
las vegas,nv
I cracked the bleeders open and nothing from each one.brake pedal is so dam stiff u could hardly pump it.
#2626661
02/27/19 10:30 AM
02/27/19 10:30 AM
Posts: 10,141 A Red State
SNK-EYZ
A Red State
If your talkin about the black rubber one,its been replaced. New doesn't always mean that it's good. As has been stated, start at the back and crack the lines loose and work your way forward to a point that you get fluid coming out. It's either a blockage or a brake valve problem.
#2626666
02/27/19 11:20 AM
02/27/19 11:20 AM
Supercuda
About to go away
About to go away
up yours
I cracked the bleeders open and nothing from each one.brake pedal is so dam stiff u could hardly pump it. the bleeders are at the end of the line. You have the connection where the hose connects tot eh body hard line. crack it there and see if you get anything. If not, the hard line connects tot eh combination valve, crack the fitting there and see if you get anything. The combination valve is fed from the M/C, crack the fitting there and see if you get anything. the problem will lay between the first leaking connection and the last one that didn't leak. If nothing comes out of the M/C that is your issue.
#2626678
02/27/19 11:50 AM
02/27/19 11:50 AM
Posts: 601 Mass
charge70
Mass
Get a helper and start bleeding brake lines.Start at the master and work from there.When you stop getting fluid flow,you found the problem.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: charge70]
#2626754
02/27/19 03:43 PM
02/27/19 03:43 PM
RapidRobert
As said; grab a helper to work the pedal & you starting at the MC.
