Help I.D. This CAM.. maybe Arrington? #262584
03/22/09 10:27 PM
03/22/09 10:27 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
I have a R5 cam I need to id. I think it's an arrington cam.
I'm pretty sure the grind is ARE-23XX.
There are also these numbers on the cam
A0901
39A
R (underlined)
CC
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Help I.D. This CAM.. maybe Arrington? [Re: DemonDust] #262585
03/23/09 01:08 PM
03/23/09 01:08 PM
Menomonee Falls
Menomonee Falls
SDG Motorsports
Re: Help I.D. This CAM.. maybe Arrington? [Re: DemonDust] #262586
03/23/09 09:33 PM
03/23/09 09:33 PM
Menomonee Falls
Menomonee Falls
Wow! This is the first time I've had a question no one could answer
SDG Motorsports
Re: Help I.D. This CAM.. maybe Arrington? [Re: DemonDust] #262587
03/23/09 09:47 PM
03/23/09 09:47 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Why not call Arrington's and ask?
http://www.arringtonengines.com/
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: Help I.D. This CAM.. maybe Arrington? [Re: DemonDust] #262588
03/23/09 09:49 PM
03/23/09 09:49 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
It's an Arrington Comp Cam..... Call Either Arrington or Comp. Comp might not give out the info about it...
Re: Help I.D. This CAM.. maybe Arrington? [Re: RyanJ] #262589
03/23/09 10:28 PM
03/23/09 10:28 PM
Menomonee Falls
Menomonee Falls
Will they give me the info?
I was told they won't give out that info
SDG Motorsports
Re: Help I.D. This CAM.. maybe Arrington? [Re: DemonDust] #262590
03/23/09 10:33 PM
03/23/09 10:33 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Talk to Mike at Arrington,he grinds the cams they don't outsource.
Re: Help I.D. This CAM.. maybe Arrington? [Re: goldmember] #262591
03/23/09 11:14 PM
03/23/09 11:14 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
They used to run Comp's in their Truck motors before they got their own grinder. Usually Comp will not give out lobe specs on a proprietary Nascar cam like that.... Just send it to someone with a cam doctor if you can't get them to give up the specs.
Re: Help I.D. This CAM.. maybe Arrington? [Re: RyanJ] #262592
03/23/09 11:15 PM
03/23/09 11:15 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Re: Help I.D. This CAM.. maybe Arrington? [Re: DemonDust] #262593
03/23/09 11:17 PM
03/23/09 11:17 PM
Carbondale PA
Domino1609 Offline
Domino1609  Offline
Carbondale PA
Call later Tuesday,I did a bunch of those on the cam doc, I have the sheets at the shop.
Rick
570-561-1746
Re: Help I.D. This CAM.. maybe Arrington? [Re: Domino1609] #262594
03/24/09 12:55 AM
03/24/09 12:55 AM
Menomonee Falls
Menomonee Falls
Thanks guys for the help.
Rick, I'll give you a call tomorrow afternoon. I need to talk to you anyway.
SDG Motorsports
