Re: New slant six blower
[Re: fourgearsavoy]
#2623798
02/20/19 05:30 PM
02/20/19 05:30 PM
Posts: 20,185 Park Forest, IL
slantzilla
Park Forest, IL
Those have been out for awhile. Kit is reasonably cheap, and a few are out there. I've been thinking about one for my junk. Buddy of mine has one he's putting in a '64 Dart. I'm watching closely.
[Re: fourgearsavoy]
#2623799
02/20/19 05:31 PM
02/20/19 05:31 PM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Luke Duke was running a boosted Slant Six in the 80s, before boosted became a thing. Turbo and roots I believe.
[Re: CMcAllister]
#2624100
02/21/19 09:09 AM
02/21/19 09:09 AM
Posts: 193 Sharpsburg Maryland
440farmer
Sharpsburg Maryland
Luke Duke was running a boosted Slant Six in the 80s, before boosted became a thing. Turbo and roots I believe. Yeah I remember him he had roots type blower driven by v belt and from what I can recall the damn thing ran pretty good. He was certainly a character even broke down his wheels and tires to run slicks for the day...
[Re: fourgearsavoy]
#2624159
02/21/19 01:08 PM
02/21/19 01:08 PM
Posts: 4,209 New York
polyspheric
New York
A centrifugal makes a better package than roots. 1. can be intercooled (as a blow-through) 2. no visible mods (like that giant cop-magnet hole in the hood) 3. weighs less 4. requires less parasitic drag per pound of boost 5. lower charge temperature Disadvantage: not much torque increases until it's spun up, so it needs a looser convert to launch. Advantage over NA: equal and tuned header length is relatively unimportant, but should use primary OD based on power delivered, not engine size.
Boffin Emeritus
[Re: gzig5]
#2624192
02/21/19 02:02 PM
02/21/19 02:02 PM
slantzilla
Park Forest, IL
I have 2 of those in my shop now. I will be building a mounting plate and carb mount for a draw through setup. Not the most efficient power wise, but it will look cool at the cruise nights he goes to.
[Re: polyspheric]
#2624290
02/21/19 04:54 PM
02/21/19 04:54 PM
Posts: 22,696 Bitopia
jcc
Bitopia
A centrifugal makes a better package than roots. 1. can be intercooled (as a blow-through) 2. no visible mods (like that giant cop-magnet hole in the hood) 3. weighs less 4. requires less parasitic drag per pound of boost 5. lower charge temperature Disadvantage: not much torque increases until it's spun up, so it needs a looser convert to launch. Advantage over NA: equal and tuned header length is relatively unimportant, but should use primary OD based on power delivered, not engine size. Not many seem to understand the hows and whys of #5
[Re: 440farmer]
#2624365
02/21/19 07:56 PM
02/21/19 07:56 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Luke Duke was running a boosted Slant Six in the 80s, before boosted became a thing. Turbo and roots I believe. Yeah I remember him he had roots type blower driven by v belt and from what I can recall the damn thing ran pretty good. He was certainly a character even broke down his wheels and tires to run slicks for the day... He's world famous with old 75&80 guys. I'm not even gonna say what he's up to these days.
[Re: fourgearsavoy]
#2624635
02/22/19 12:14 PM
02/22/19 12:14 PM
polyspheric
New York
An Eaton works very well (lighter, smaller, cheaper, and more efficient than GMC 4-71 etc.) but the plumbing has to be doped out. Easiest is blow-through with just a filter to replace the TB, but you need to make a box to cover the entire discharge side and adapt to your intake. I've seen pictures (no details) of a 90° turn at the TB for a 4 bbl. adapter. The Eaton case can be rotated 90° or 180° to make plumbing easier. Needs no external lubrication or drain. Probably works with aftermarket 6 rib belt kits. There are several nose drive lengths available so that the discharge window can be put (more or less) where you want it. The Eaton M numbers are the charge volume of 1 rotation: M90 is 90" (about right for moderate boost on a slant), etc. and typically turn 2 to 3 × engine speed. More of my comments on my site: http://victorylibrary.com/mopar/blower/blower.htm
Boffin Emeritus
