Re: Long w2 exhaust valve source
[Re: NoFrills]
#2623733
02/20/19 03:21 PM
02/20/19 03:21 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Manley will make them for you......... but it’s probably cheaper and quicker to just put guides in the heads and get 11/32 valves.
[Re: NoFrills]
#2623847
02/20/19 06:38 PM
02/20/19 06:38 PM
Posts: 3,504 DFW
mr_340
DFW
Ferrea F6137 CHRYSLER 340 & W2 (1955 - 2012) EXHAUST 6000 SERIES COMPETITION VALVES 340 & W2 (3/8) Exhaust Valve Head Diameter: 1.600 Stem Diameter: 3/8 Overall Length: 5.225 Tip Length: 0.225 References: 15 Degree Super Flo-W2
Floyd Lippencott IV
[Re: NoFrills]
#2623963
02/20/19 10:49 PM
02/20/19 10:49 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I tried to order from a few dealers and from Ferra directly. Those valves are no longer in stock. Was told they have no plans on making them again. I honestly can’t blame them in 3/8 stem. Were the ones in the W2 econo heads the long length valves. If so let me know and you can have the set out of my cracked W2 heads.
[Re: pittsburghracer]
#2624021
02/21/19 12:33 AM
02/21/19 12:33 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Never mind I can’t help you. The intakes are 3/8 and the exhaust are smaller diameter. Oh well I tried
