Re: 92' B250 engine/electrical question
[Re: BulletBob]
#2619568
02/10/19 10:55 PM
02/10/19 10:55 PM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
Check for spark, check fuel pressure. That continuing to turn over after releasing the key is weird though. Maybe the ignition switch?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: BulletBob]
#2619574
02/10/19 11:01 PM
02/10/19 11:01 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
run the codes, see what the computer thinks is going on. https://www.allpar.com/fix/80s-codes.html
[Re: BulletBob]
#2619605
02/11/19 12:09 AM
02/11/19 12:09 AM
Supercuda
About to go away
About to go away
up yours
When you say "won't crank" what exactly does that mean? To me it means the starter will not spin the engine over.
Do you mean that?
[Re: BulletBob]
#2619620
02/11/19 12:38 AM
02/11/19 12:38 AM
Guitar Jones
I'm confused now. Did the starter continue cranking the engine over when you released the key?
[Re: BulletBob]
#2619638
02/11/19 01:17 AM
02/11/19 01:17 AM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
You need to get the terms correct so everyone understands what you are telling us.
1) Crank or no crank = the starter spinning the motor over, or the starter not spinning the motor over.
2) start or no start = the engine running after the starter spins it over, or the engine does not start after the starter spins the motor over.
3) Spark or no spark = when the starter is spinning the motor over, you have a spark between the plug (or coil) wire and a ground, or while the starter is spinning the motor over, you do not have a spark between a plug (or coil) wire and a ground.
If you have no spark, spraying either into the motor will have no effect.
If the starter is still spinning the motor over after the key has been shut off, you have an electrical problem that may also be effecting the no start problem. It could be an ignition switch, or something shorting out in the wiring, or a bad relay. Gene
[Re: BulletBob]
#2620375
02/12/19 06:17 PM
02/12/19 06:17 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Those things have a bundle of fusible links that connect the power under the hood to the fuse box under the dash. That's always a good place to start researching electrical issues.
[Re: feets]
#2620424
02/12/19 07:26 PM
02/12/19 07:26 PM
Guitar Jones
Yeah but fuse links are either good or they are not. Intermittent problems are generally not associated with them.
[Re: Guitar Jones]
#2620476
02/12/19 08:39 PM
02/12/19 08:39 PM
feets
Senior Management
Senior Management
Irving, TX
Yeah but fuse links are either good or they are not. Intermittent problems are generally not associated with them. HA! I've got over 20 years experience with a 92 D250 that begs to differ. When they get old and crusty they sometimes work and sometimes don't. Every now and then the systems backfeed and pull power from weird places. Kinda like when I hit the power window switch and EVERY warning light on the dash lit up. ABS, brake warning, water in fuel, wait to start, and all the others would light. I fixed that one and the same thing would happen when I tried to turn on the A/C blower.
[Re: feets]
#2620489
02/12/19 09:27 PM
02/12/19 09:27 PM
Guitar Jones
Whatever dude, I've been a tech for 45 years now and worked on them when they were brand new and owned plenty over the years. What you just described sounds more like a bad ground. Which can burn out a fuse link. Something those old D and W series are famous for. Bob however is asking about a B van. Similar but different.
Ya know you don't have to thump your chest everytime someone disagrees with you Mr. Mercedes Parts Counter Man. Ok?
[Re: Guitar Jones]
#2620556
02/12/19 11:21 PM
02/12/19 11:21 PM
feets
Senior Management
Senior Management
Irving, TX
Ya know you don't have to thump your chest everytime someone disagrees with you Mr. Mercedes Parts Counter Man. Ok? I'm not a tech and do not pretend to be one. The fact that I toss parts to techs means nothing in this situation. I'm sure in your 45 years of fighting cars you've had some serious electrical head scratchers. In my case, fixing grounds helped some of the issues but did not fix all of the issues. The weirdo malfunctions and mishaps went away when I removed the bundle of fusible links and replaced them with a maxi fuse block I scrounged from a Cadillac in the salvage yards. Those old fusible links get the crusty green death over the years. Sometimes they carry current well, other times they don't. They looked fine from the outside but 27 years of life under the hood took a toll on them. They may or may not have anything to do with the issue he's having but it's not going to hurt to check them for proper current capacity.
