Removing drip Rails #2619234
02/09/19 11:32 PM
02/09/19 11:32 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Say on an E body, what's involved in losing the drip rails, for looks, aero, etc. Skill set needed? Any hidden land mines? eek
Those that have done it, would you do it again, any regrets?
Re: Removing drip Rails [Re: jcc] #2619236
02/09/19 11:37 PM
02/09/19 11:37 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
They are held on with screws from under the weatherstripping so very easy to remove.
Re: Removing drip Rails [Re: jcc] #2619296
02/10/19 06:32 AM
02/10/19 06:32 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Sorry Nanket is wrong....the drip rails are where the upper roof skin is welded to the lower structure....when you cut of the drip rail the upper roof skin must be carefully rewelded to the lower structure.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Removing drip Rails [Re: jcc] #2619297
02/10/19 08:11 AM
02/10/19 08:11 AM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
Alternatively, one can trim off the lip for the stainless then fold the pinch weld down into the window opening.
Angry white pureblood male
Re: Removing drip Rails [Re: ruderunner] #2619359
02/10/19 02:20 PM
02/10/19 02:20 PM
moparx Offline
moparx  Offline
would you, per chance, have a pic of this method ? TIA up
beer
Re: Removing drip Rails [Re: moparx] #2619370
02/10/19 02:38 PM
02/10/19 02:38 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
A little more background, the car in question will be getting a full cage, and removing the roof makes that a lot easier to install, so I was wondering if this drip rail removal might be part of the project.
Re: Removing drip Rails [Re: jcc] #2619403
02/10/19 03:28 PM
02/10/19 03:28 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
Definitely not a project for a novice welder since re-welding the top skin back on without warping it takes a lot of skill. Basically its not something that will make a difference on the race track either. Good luck though, if you decide to do it.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: Removing drip Rails [Re: jcc] #2619452
02/10/19 05:24 PM
02/10/19 05:24 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The drip rail on E body cars is the stainless trim. There is no drip rail made of the body sheet metal like A and B bodies. It is like a flat flange where the spot welds are.
Re: Removing drip Rails [Re: NANKET] #2619572
02/10/19 11:00 PM
02/10/19 11:00 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
It's still called the drip rail on an E-Body, the trim is called the Drip Rail Molding.
Re: Removing drip Rails [Re: jcc] #2619669
02/11/19 03:44 AM
02/11/19 03:44 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Glue it back on
Re: Removing drip Rails [Re: jcc] #2619675
02/11/19 05:31 AM
02/11/19 05:31 AM
If you want to remove the roof so it can be put back on and look like is was never off grind the body putty off of the front wind shield posts and the C pillar between side windows and rear back glass and remove the factory spot welds and reuse those holes to put it back on scope up twocents
The better race car shops the due complete SFI cages use that method so they can weld the top of all the bars weld
