1969 Charger AC Control vacuum Canister Location? #2619039
02/09/19 01:40 PM
02/09/19 01:40 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Good Morning Everyone,
I just received a reconditioned AC/Heater control vacuum canister (small one) and for the life of me can not find where it mounts. I have the service manual, and have searched the internet. Anyone point me in the right direction, or have a pic?
Thanks in advance!!
Re: 1969 Charger AC Control vacuum Canister Location? [Re: jim6346] #2619053
02/09/19 02:18 PM
02/09/19 02:18 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
I don't know about 69 Charger, but my 71 Satellite has it under the battery tray.
Re: 1969 Charger AC Control vacuum Canister Location? [Re: jim6346] #2619058
02/09/19 02:29 PM
02/09/19 02:29 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
parts book can usually give an idea where it goes, though in this case, not so much.
This might help
http://www.dodgecharger.com/forum/index.php?topic=19205.0
Don't be the exception.
Re: 1969 Charger AC Control vacuum Canister Location? [Re: jim6346] #2619062
02/09/19 02:33 PM
02/09/19 02:33 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Thanks, but these cover the large headlight vacuum canister, under the battery tray. I am looking for the small vacuum canister location that runs to the Heater/AC controls.
Thanks,
Re: 1969 Charger AC Control vacuum Canister Location? [Re: jim6346] #2619064
02/09/19 02:35 PM
02/09/19 02:35 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
is this the one that looks like a coffee can or a plastic ball?
Re: 1969 Charger AC Control vacuum Canister Location? [Re: jim6346] #2619065
02/09/19 02:37 PM
02/09/19 02:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Is it mounted on the heater a/c housing?
Re: 1969 Charger AC Control vacuum Canister Location? [Re: jim6346] #2619066
02/09/19 02:38 PM
02/09/19 02:38 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
68 & 69 Charger does not use one, ONLY for the headlights
Re: 1969 Charger AC Control vacuum Canister Location? [Re: jim6346] #2619074
02/09/19 03:02 PM
02/09/19 03:02 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Hi CSK,
Then do you know where the vacuum lines that go to the AC/Heater Control
are connected? Do they just run to the engine vacuum?
Thanks!!
Re: 1969 Charger AC Control vacuum Canister Location? [Re: jim6346] #2619076
02/09/19 03:06 PM
02/09/19 03:06 PM
Andrewh Offline
Andrewh  Offline
I have never seen one for ac controls.
they generally tap vacuum off the christmas tree (if you have power brakes) off the back of the intake manifold.
can you post a pic of this canister you have?
Re: 1969 Charger AC Control vacuum Canister Location? [Re: Andrewh] #2619079
02/09/19 03:22 PM
02/09/19 03:22 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Not sure if this link will work:
https://1drv.ms/u/s!Apd0KxtKLRw_g9RVR7CcOMPqCjRKMg
[img:left]https://1drv.ms/u/s!Apd0KxtKLRw_g9RVR7CcOMPqCjRKMg[/img]
Thanks,
Re: 1969 Charger AC Control vacuum Canister Location? [Re: jim6346] #2619081
02/09/19 03:26 PM
02/09/19 03:26 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
[img]https://1drv.ms/u/s!Apd0KxtKLRw_g9RVR7CcOMPqCjRKMg[/img]
Re: 1969 Charger AC Control vacuum Canister Location? [Re: Andrewh] #2619090
02/09/19 03:52 PM
02/09/19 03:52 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
This ^^^^^
Re: 1969 Charger AC Control vacuum Canister Location? [Re: jim6346] #2619095
02/09/19 04:03 PM
02/09/19 04:03 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Well that stinks, anyone need a small vacuum canister or know what it is for lol...
Thanks everyone!!
Re: 1969 Charger AC Control vacuum Canister Location? [Re: jim6346] #2619099
02/09/19 04:11 PM
02/09/19 04:11 PM
USA
Grizzly69 Offline
Grizzly69  Offline
USA
There is a small vacuum can under the battery tray on my 1970 Charger parts car. I think it has something to do with the A/C.
Re: 1969 Charger AC Control vacuum Canister Location? [Re: Grizzly69] #2619107
02/09/19 04:26 PM
02/09/19 04:26 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Yes, the 70 B body uses a small canister under the battery tray mounted to the front/inside radiator yoke...I'll look at the factory prints to see if I have anything on 68-9 B body AC set ups?
Mike
Re: 1969 Charger AC Control vacuum Canister Location? [Re: jim6346] #2619178
02/09/19 08:05 PM
02/09/19 08:05 PM
Andrewh Offline
Andrewh  Offline
https://www.classicindustries.com/produc...N8aAq8wEALw_wcB
apparently so.
the repro ones don't look the same.
I would have guessed for some of the low vacuum cars but I thought those couldn't be had with a/c anyway.
but I guess even the heat only cars needed vacuum for the switch.
Re: 1969 Charger AC Control vacuum Canister Location? [Re: Andrewh] #2619353
02/10/19 02:04 PM
02/10/19 02:04 PM
moparx Online content
moparx  Online Content
i'm confused. [nothing new there ! biggrin] my 69 has the can under the battery tray for the headlights, but it looks identical to the "ac" can shown in the link to classic. "if" i had ac, would this can also be used in conjunction with the ac controls, or would my car get vacuum from the christmas tree on the intake, or both ?
beer
