Re: 1969 Charger AC Control vacuum Canister Location?
[Re: jim6346]
#2619058
02/09/19 02:29 PM
02/09/19 02:29 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
parts book can usually give an idea where it goes, though in this case, not so much. This might help http://www.dodgecharger.com/forum/index.php?topic=19205.0
[Re: jim6346]
#2619064
02/09/19 02:35 PM
02/09/19 02:35 PM
Supercuda
About to go away
About to go away
up yours
is this the one that looks like a coffee can or a plastic ball?
[Re: jim6346]
#2619066
02/09/19 02:38 PM
02/09/19 02:38 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
68 & 69 Charger does not use one, ONLY for the headlights
[Re: Andrewh]
#2619090
02/09/19 03:52 PM
02/09/19 03:52 PM
CSK
Pattison Texas
I have never seen one for ac controls. they generally tap vacuum off the christmas tree (if you have power brakes) off the back of the intake manifold.
can you post a pic of this canister you have? This ^^^^^
[Re: Grizzly69]
#2619107
02/09/19 04:26 PM
02/09/19 04:26 PM
Posts: 18,157 Mass
DAYCLONA
Mass
There is a small vacuum can under the battery tray on my 1970 Charger parts car. I think it has something to do with the A/C.
Yes, the 70 B body uses a small canister under the battery tray mounted to the front/inside radiator yoke...I'll look at the factory prints to see if I have anything on 68-9 B body AC set ups? Mike
[Re: jim6346]
#2619178
02/09/19 08:05 PM
02/09/19 08:05 PM
Andrewh
https://www.classicindustries.com/produc...N8aAq8wEALw_wcBapparently so. the repro ones don't look the same. I would have guessed for some of the low vacuum cars but I thought those couldn't be had with a/c anyway. but I guess even the heat only cars needed vacuum for the switch.
