Driveshaft Slip Yoke Travel #2617065
02/04/19 10:42 PM
02/04/19 10:42 PM
MD
RTSE4ME Offline OP
RTSE4ME  Offline OP
MD
Is 7/8" enough slip yoke travel before it bottoms out?
1970 440 4speed challenger with b-body dana and Hotchkis springs. I am using the same driveshaft when I had a 8 3/4....45 1/2" long.
I know the Dana should have a 1" shorter driveshaft.
Re: Driveshaft Slip Yoke Travel [Re: RTSE4ME] #2617087
02/04/19 11:27 PM
02/04/19 11:27 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
should be fine , i normaly shoot for 1"
Re: Driveshaft Slip Yoke Travel [Re: RTSE4ME] #2617102
02/04/19 11:42 PM
02/04/19 11:42 PM
I was taught with the car on the ground with the weight on the tires and suspension to slide the yoke all the way in until it bottomed out and then slide it back towards the rear end 3/4 inch for making the driveshaft length correct, that has worked very well for me up
Re: Driveshaft Slip Yoke Travel [Re: RTSE4ME] #2617121
02/05/19 12:25 AM
02/05/19 12:25 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Sounds good to me.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Driveshaft Slip Yoke Travel [Re: GoodysGotaCuda] #2617136
02/05/19 12:59 AM
02/05/19 12:59 AM
Is that 7/8 loaded? If so that is plenty & I like 5/8-3/4. (depends of the intent use).
Re: Driveshaft Slip Yoke Travel [Re: RapidRobert] #2617168
02/05/19 02:32 AM
02/05/19 02:32 AM
MD
RTSE4ME Offline OP
RTSE4ME  Offline OP
MD
Yes loaded. I was kind of surprised the same driveshaft from the 8 3/4 fits.
Re: Driveshaft Slip Yoke Travel [Re: RTSE4ME] #2617273
02/05/19 01:00 PM
02/05/19 01:00 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
It is probably more than enough, maybe too much. Instead of more than enough, I prefer just enough. It makes for a more stable yoke.
The 1" clearance is a blanket rule to cover everything including trucks. They sit high, lots of clearance and are often loaded, less clearance.
If a car sits low and loaded. The clearance of 1" will never come close to bottoming out. It will only pull out as the suspension droops. It may move forward less than 1/4".
Re: Driveshaft Slip Yoke Travel [Re: Magnum] #2617344
02/05/19 03:24 PM
02/05/19 03:24 PM
moparx Offline
moparx  Offline
this brings up the question of which seal is on the tailshaft, the shielded one, or the cheapo one without the big, rubber end.
and, as always, i have done the "bottom, then pull out 3/4", but i don't remember if that was with, or without, the shielded seal in place.
refresh my memory please !
beer
Re: Driveshaft Slip Yoke Travel [Re: moparx] #2617352
02/05/19 03:52 PM
02/05/19 03:52 PM
Without, & yes you are (loosing) it! (it'll get worse)
Re: Driveshaft Slip Yoke Travel [Re: RapidRobert] #2617397
02/05/19 05:45 PM
02/05/19 05:45 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Do the math.
Re: Driveshaft Slip Yoke Travel [Re: John_Kunkel] #2617412
02/05/19 06:21 PM
02/05/19 06:21 PM
it's to bad they don't show how far out the output shaft sticks out from the tail shaft housing seal work whiney
Re: Driveshaft Slip Yoke Travel [Re: RTSE4ME] #2617641
02/06/19 02:58 AM
02/06/19 02:58 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
On my 2 original dana cars one the bulb seal runs 1/8 from end of bulb to driveshaft yoke, the other is 1/4. It works out to about an inch out. Do not make it 1" out from a bulb type seal, that is wrong. 3/4 to 1" from a flat seal. Things move more than you think sometimes, and too far in could maybe knock the plug out of the yoke.
Re: Driveshaft Slip Yoke Travel [Re: RTSE4ME] #2617673
02/06/19 09:23 AM
02/06/19 09:23 AM
BDW Online content
BDW  Online Content
Re: Driveshaft Slip Yoke Travel [Re: 4406bbl] #2617674
02/06/19 09:23 AM
02/06/19 09:23 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
1970 440 4speed challenger with b-body dana and Hotchkis springs......same driveshaft when I had a 8 3/4
I'm doing the same except with stock HD springs.....5 yrs, 6000 miles, no problems up
jess
Yeah, it's hopped up to over 160...
Re: Driveshaft Slip Yoke Travel [Re: John_Kunkel] #2617827
02/06/19 02:22 PM
02/06/19 02:22 PM
moparx Offline
moparx  Offline
Originally Posted By John_Kunkel
Do the math.
it's a good thing you are here john ! thanks ! up
beer
