Re: Driveshaft Slip Yoke Travel
[Re: GoodysGotaCuda]
#2617136
02/05/19 12:59 AM
02/05/19 12:59 AM
RapidRobert
Is that 7/8 loaded? If so that is plenty & I like 5/8-3/4. (depends of the intent use).
[Re: RTSE4ME]
#2617273
02/05/19 01:00 PM
02/05/19 01:00 PM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
It is probably more than enough, maybe too much. Instead of more than enough, I prefer just enough. It makes for a more stable yoke.
The 1" clearance is a blanket rule to cover everything including trucks. They sit high, lots of clearance and are often loaded, less clearance.
If a car sits low and loaded. The clearance of 1" will never come close to bottoming out. It will only pull out as the suspension droops. It may move forward less than 1/4".
[Re: Magnum]
#2617344
02/05/19 03:24 PM
02/05/19 03:24 PM
Posts: 19,307 north of coder
moparx
this brings up the question of which seal is on the tailshaft, the shielded one, or the cheapo one without the big, rubber end. and, as always, i have done the "bottom, then pull out 3/4", but i don't remember if that was with, or without, the shielded seal in place. refresh my memory please !
[Re: moparx]
#2617352
02/05/19 03:52 PM
02/05/19 03:52 PM
RapidRobert
Without, & yes you are (loosing) it! (it'll get worse)
[Re: RTSE4ME]
#2617673
02/06/19 09:23 AM
02/06/19 09:23 AM
Posts: 4,703 Florida
BDW
[Re: 4406bbl]
#2617674
02/06/19 09:23 AM
02/06/19 09:23 AM
Posts: 1,567 Ky
jt4406
Ky
1970 440 4speed challenger with b-body dana and Hotchkis springs......same driveshaft when I had a 8 3/4 I'm doing the same except with stock HD springs.....5 yrs, 6000 miles, no problems jess
Yeah, it's hopped up to over 160...
