440 into a 66 Fury..motor mounts? #2615930
02/02/19 01:04 PM
02/02/19 01:04 PM
S.E. Missouri
AeroMonte Offline OP
S.E. Missouri
Our 66 Sport Fury came with a 318 originally. I have a 440 from a 73 New Yorker. What engine mounts will I need for the swap to bolt to the subframe?
Re: 440 into a 66 Fury..motor mounts? [Re: AeroMonte] #2615931
02/02/19 01:08 PM
02/02/19 01:08 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
IIRC the SB mounts should work.Been a while since Ive done a swap on a C body.I know my 65 B body uses the same BB and SB.Rocky
Chrysler Firepower
Re: 440 into a 66 Fury..motor mounts? [Re: therocks] #2615933
02/02/19 01:10 PM
02/02/19 01:10 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Think he's asking about the brackets, which aren't the same IIRC.
http://engine-swaps.com/ seems to say the donors are '66-72 B, '70-74 E, '66-73 C-Body B/RB
Don't be the exception.
Re: 440 into a 66 Fury..motor mounts? [Re: AeroMonte] #2615981
02/02/19 02:35 PM
02/02/19 02:35 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The engine brackets are different from SB to BB. The rubber mounts appear the same.
The subframe mount stands in the car are the same.
Re: 440 into a 66 Fury..motor mounts? [Re: NANKET] #2616005
02/02/19 03:22 PM
02/02/19 03:22 PM
^^^ Ding ding ding I do believe we have a winna.
Re: 440 into a 66 Fury..motor mounts? [Re: AeroMonte] #2616167
02/02/19 09:20 PM
02/02/19 09:20 PM
west palm beach, florida
modelmakerinc Offline
The mounts and brackets from the 73 c body will work in the 66 they have the same subframe, while you are at it grab the disk brakes, brake booster and prop valve and upgrade the stopping of your Fury
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: 440 into a 66 Fury..motor mounts? [Re: AeroMonte] #2616234
02/03/19 12:21 AM
02/03/19 12:21 AM
S.E. Missouri
S.E. Missouri
Thanks modelmakerinc...what size rear tires are you running on that Fury?
Nanket, sent you a message. Thanks everybody
Re: 440 into a 66 Fury..motor mounts? [Re: AeroMonte] #2616264
02/03/19 01:16 AM
02/03/19 01:16 AM
They are discontinued BFG drag radials 345-55-15. About 13" of tread, another 4" of side bulge mounted on 12" wheels.
It was mini-tubbed and SS springs inboarded.
Re: 440 into a 66 Fury..motor mounts? [Re: AeroMonte] #2616324
02/03/19 09:56 AM
02/03/19 09:56 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
One bad looking Fury 65 to 68 were some of the best looking made to me.Rocky
Chrysler Firepower
Re: 440 into a 66 Fury..motor mounts? [Re: AeroMonte] #2616387
02/03/19 12:31 PM
02/03/19 12:31 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
That Fury is extra cool and Bad [censored]! It has a combat ready look.
Keep old mopars alive.
Re: 440 into a 66 Fury..motor mounts? [Re: AeroMonte] #2616446
02/03/19 03:05 PM
02/03/19 03:05 PM
S.E. Missouri
S.E. Missouri
This is what we are working on. Same owner since the early 80's. We gave $320 for it then added the wheels. Spent the day yesterday at Clay & Sons in Catawissa Mo and got every tittle piece that was missing. Now to get it running and driving again.
Re: 440 into a 66 Fury..motor mounts? [Re: AeroMonte] #2616844
02/04/19 01:31 PM
02/04/19 01:31 PM
moparx Online content
moparx  Online Content
pretty neat ride. you are leaving the skirts on [i hope up] ?
beer
Re: 440 into a 66 Fury..motor mounts? [Re: NANKET] #2616856
02/04/19 01:53 PM
02/04/19 01:53 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
"If" 66 K member is the same as 65,the driver side bracket top bolt hole goes to a threaded boss on the front of the block.
Re: 440 into a 66 Fury..motor mounts? [Re: AeroMonte] #2616878
02/04/19 02:41 PM
02/04/19 02:41 PM
65 is different, 66 through 73 are the same subframe, the C-bodies don't have a K-frame.
Like what was said, the engine blocks are like an big block, A body block with a threaded boss on the front of #1 cylinder. And use unique driver side engine mount brackets.
Re: 440 into a 66 Fury..motor mounts? [Re: modelmakerinc] #2616964
02/04/19 05:52 PM
02/04/19 05:52 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Well, my 66 New Yorker had a 440, you might be able to find some info
there as it was a C body too.
Joe
Re: 440 into a 66 Fury..motor mounts? [Re: 2boltmain] #2617317
02/05/19 02:49 PM
02/05/19 02:49 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
B/C/Y/E Big block engine mounting brackets
Re: 440 into a 66 Fury..motor mounts? [Re: Joesixpack] #2617319
02/05/19 02:52 PM
02/05/19 02:52 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
66-72 b body,66-73 c&y body, 70-71 e body(also fit 72-74 when dropping in a big block
Re: 440 into a 66 Fury..motor mounts? [Re: Joesixpack] #2617320
02/05/19 02:55 PM
02/05/19 02:55 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
65 big block c body uses the 383 abody drivers side wrap around mount...on the drivers side....
Re: 440 into a 66 Fury..motor mounts? [Re: Joesixpack] #2617327
02/05/19 03:00 PM
02/05/19 03:00 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
passenger side 65 c body big block uses one of the 63-64-65 bbody big block brackets...
Re: 440 into a 66 Fury..motor mounts? [Re: Joesixpack] #2617329
02/05/19 03:01 PM
02/05/19 03:01 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
1967-1968-1969 383 abody uses the wrap around driver side bracket and the 66 to 72 bbody passenger side bracket on the passenger side!
