12 volt to 16 volt I picked this little unit up I picked up #2616112
02/02/19 07:29 PM
02/02/19 07:29 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
I. Discovered this little converter on the internet my plans is install this on the fuel pump to convert my 12 volt system to 16 volt at the pump what is your guys's thoughts fire away. Aside from it being made in China I think it could be a player
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: 12 volt to 16 volt I picked this little unit up I picked up [Re: WHITEDART] #2616121
02/02/19 07:37 PM
02/02/19 07:37 PM
What is the max rating in amps will your fuel pump draw at WOT?
If below 10 amps go for it, if more than 10 amps run two or three of them in parallel twocents
Re: 12 volt to 16 volt I picked this little unit up I picked up [Re: WHITEDART] #2616236
02/03/19 12:27 AM
02/03/19 12:27 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
What type of pump is it? Most everyone, myself included just runs everything on 16 without stepping it down.
Re: 12 volt to 16 volt I picked this little unit up I picked up [Re: dthemi] #2616253
02/03/19 12:49 AM
02/03/19 12:49 AM
bean town ....Ca
W
W
bean town ....Ca
I apologize maybe I didn't explain it properly my car is a 12-volt system but I wanted to up the voltage at the pump it is a quick fuel 427.. so I basically and upping the voltage to the fuel pump only
Re: 12 volt to 16 volt I picked this little unit up I picked up [Re: WHITEDART] #2616255
02/03/19 12:52 AM
02/03/19 12:52 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
If your pump can't keep up this might help. It might also screw with your whole fuel curve. Can your regulator handle the extra flow/pressure? (return/deadhead)
Re: 12 volt to 16 volt I picked this little unit up I picked up [Re: WHITEDART] #2616259
02/03/19 01:03 AM
02/03/19 01:03 AM
Conroe , Texas
I
iapco103 Offline
iapco103  Offline
I
Conroe , Texas
this made think of the Kenne Bell Boost-A-Pump. Does the same thing you are trying to do. Paul
Re: 12 volt to 16 volt I picked this little unit up I picked up [Re: @#$%&*!] #2616262
02/03/19 01:12 AM
02/03/19 01:12 AM
bean town ....Ca
W
W
bean town ....Ca
. I have the Aeromotive Pro Stock regulator deadhead system I think the regulator . Should be fine. We were seen a slight amount of fuel pressure loss on a pass.. just trying to make it a little more stable ideally I would like to go to a complete 16 volt system. In the near future
Re: 12 volt to 16 volt I picked this little unit up I picked up [Re: iapco103] #2616265
02/03/19 01:16 AM
02/03/19 01:16 AM
bean town ....Ca
W
W
bean town ....Ca
I had forgot about that . A friend of mine ran a boost a. pump on a Ford Lightning truck had to have been 20 years ago.. .
Re: 12 volt to 16 volt I picked this little unit up I picked up [Re: WHITEDART] #2616295
02/03/19 02:53 AM
02/03/19 02:53 AM
bean town ....Ca
W
W
bean town ....Ca
These voltage readings we're with the pump running before and after the voltage converter
Re: 12 volt to 16 volt I picked this little unit up I picked up [Re: WHITEDART] #2616304
02/03/19 03:35 AM
02/03/19 03:35 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
At the 11.39v reading . Why have you not solved the voltage drop ?
Wire sizing/relay ?
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 12 volt to 16 volt I picked this little unit up I picked up [Re: tex013] #2616351
02/03/19 11:03 AM
02/03/19 11:03 AM
bean town ....Ca
W
W
bean town ....Ca
This is a total lost system.. the battery is a little low.the pump has a relay with the proper size wire. Wire length is less than 12in long..I will check after I charge the battery. Hopefully the output volts won't be to high..
Re: 12 volt to 16 volt I picked this little unit up I picked up [Re: WHITEDART] #2616366
02/03/19 11:48 AM
02/03/19 11:48 AM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
Is it that you don't want to add any weight to the car to go 16v on the battery itself?
Re: 12 volt to 16 volt I picked this little unit up I picked up [Re: WHITEDART] #2616368
02/03/19 11:57 AM
02/03/19 11:57 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Guess I could have read the label on the transformer lol. 12v to 16v...
I like the entire swap to 16. Better cooling, fan, and pump. More fuel, better ignition ect.
Re: 12 volt to 16 volt I picked this little unit up I picked up [Re: Deepockets] #2616375
02/03/19 12:08 PM
02/03/19 12:08 PM
bean town ....Ca
W
W
bean town ....Ca
I will probably make the change pretty soon. The problem is anti-gravity battery set me up with multiple lithium batteries and chargers and it is all 12 volt.this is a 20$ test on a 12 volt system..
Re: 12 volt to 16 volt I picked this little unit up I picked up [Re: WHITEDART] #2616384
02/03/19 12:24 PM
02/03/19 12:24 PM
ky
68roadrunner Offline
ky
the msd would like that too i think
Re: 12 volt to 16 volt I picked this little unit up I picked up [Re: WHITEDART] #2616393
02/03/19 12:43 PM
02/03/19 12:43 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I'd like to see a voltage boost on the ignition system, also. When I used to run without an alternator, if I turned a battery charger on during idling, the engine would pick up rpm. If you have 11.3 at the fuel pump, the ignition can't be much different.
Re: 12 volt to 16 volt I picked this little unit up I picked up [Re: sgcuda] #2616400
02/03/19 01:02 PM
02/03/19 01:02 PM
bean town ....Ca
W
W
bean town ....Ca
Like I had mentioned before the battery voltage.was low And definitely . Needed to be charged ..that being said I agree With you. I think all roads will lead to 16 volt for me in the future
Re: 12 volt to 16 volt I picked this little unit up I picked up [Re: WHITEDART] #2616454
02/03/19 03:34 PM
02/03/19 03:34 PM
One thing to learn about electric power is as the voltage is increase, AC or DC, the amperage used will go down to accomplish the same work.
Lower voltage will increase the amperage needed to accomplish the same work scope
I don't remember the formula now for figuring out the amps needed with the existing voltage to provide for the watts used to do the work blush
Amps do the work, not Volts tsk
Re: 12 volt to 16 volt I picked this little unit up I picked up [Re: Cab_Burge] #2616479
02/03/19 04:44 PM
02/03/19 04:44 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Cab watts is power(work) volts x amps = watts
"Just a Bracket car dressed up like a streetcar"
Re: 12 volt to 16 volt I picked this little unit up I picked up [Re: Cab_Burge] #2616484
02/03/19 04:51 PM
02/03/19 04:51 PM
Morrow, OH
markz528 Online content
markz528  Online Content
Morrow, OH
You have to be careful with that analogy on centrifugal devices like pumps. They are governed by affinity laws.
Affinity laws state that the flow is the square of the speed and the hp required is the cube of the flow. In a DC motor, speed is proportional to voltage. So drop the voltage the hp drops a lot so amps actually go down. Also a motor is a torque matching device so it does not follow ohm's law.
Ignoring losses, assume a water or fuel pump draws 10 amps @ 16 volts. That equals to 160 watts.
Drop the voltage to 12 volts, voltage drops 25%, the flow drops to 56.25% of previous flow and horsepower drops 42.19% of previous hp (67.5 watts). So 67.5/12 = 5.62 amps.
So in this case when the voltage drops from 16 to 12 volts the amps actually drop from 10 to 5.62 amps and you have 56.25% of the original flow. Pretty sure my math is right. Results would not be exact due to losses and some other considerations, but it won't be that far off.
It also works the other direction. When I went from a 50 to a 120 amp alternator, my running voltage went from around 11.8 to just under 14 volts. I dropped over 20 degrees returning to the pits after a run because of these laws. My amp requirement went up a lot!
