Page 1 of 3 1 2 3
TOP DEAD CENTER TRICK #2615949
02/02/19 01:53 PM
02/02/19 01:53 PM
Texas
Moparmad Offline OP
Moparmad  Offline OP
Texas
TRICK I LEARNED IS TO PUT A LITTLE PLASTIC PIPE PLUG(PUSH IN KIND) INTO #1 SPARK PLUG HOLE. TURN CRANK UNTIL PLUG SHOOTS 8 FOOT IN THE AIR AND VOILA YOU ARE ON THE COMPRESION STROKE. SET CRANK AT 0.
Re: TOP DEAD CENTER TRICK [Re: Moparmad] #2615966
02/02/19 02:13 PM
02/02/19 02:13 PM
Kirkland, Washington
Pacnorthcuda Offline
And what is your trick for getting the plug out when you suck it into the cylinder?
Re: TOP DEAD CENTER TRICK [Re: Moparmad] #2615968
02/02/19 02:15 PM
02/02/19 02:15 PM
Good trick, especially when you ain't in a position to watch the #1 or #6 rockers to confirm that. & if I am confirming the dampener TDC with the screw in tool, I get the dampener to 15 BTDC then screw it in till it makes contact then I go back around CCW till it touches again (hopefully at 15 ATDC) & I repeat it once for good measure.
Re: TOP DEAD CENTER TRICK [Re: Pacnorthcuda] #2615988
02/02/19 02:41 PM
02/02/19 02:41 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Best question ever.
Re: TOP DEAD CENTER TRICK [Re: NANKET] #2615992
02/02/19 02:50 PM
02/02/19 02:50 PM
or pay the neighbor boy a buck to hold his finger over the hole while you move the breaker. On the plastic plug if it is shaped right to where it could not get sucked inside that'd resolve that (potential) or stick a pin in it sideways. decades ago I had a plastic piece of something fall in there & people said to fire it up & I did & no issue but it was a fairly small piece iirc.
Re: TOP DEAD CENTER TRICK [Re: Pacnorthcuda] #2616000
02/02/19 03:00 PM
02/02/19 03:00 PM
Texas
Moparmad Offline OP
Moparmad  Offline OP
Texas
never had it happen. I put the plug in fairly loose and turn the crank with a ratchet slowly. it may suck in a little but it makes it easier to blow out. it is also important to have the right size plug. err on the side of a little too big.
I do also use the plug with the outer lip that is bigger than the insertion diameter.
Re: TOP DEAD CENTER TRICK [Re: Moparmad] #2616025
02/02/19 04:33 PM
02/02/19 04:33 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i just use a remote starter and my thumb shruggy
Re: TOP DEAD CENTER TRICK [Re: bonefish] #2616031
02/02/19 04:51 PM
02/02/19 04:51 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Same here, it's worked for over 4 decades for me...
Re: TOP DEAD CENTER TRICK [Re: Moparmad] #2616039
02/02/19 05:07 PM
02/02/19 05:07 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Try that with a Hemi laugh2
Re: TOP DEAD CENTER TRICK [Re: Moparmad] #2616138
02/02/19 08:03 PM
02/02/19 08:03 PM
A727Tflite Offline
A727Tflite  Offline
A clean Hemi pushrod always works when working on a Hemi.
I do t remember ever working on any car that I couldn’t bar the engine over while holding my finger over the plug hole.
Re: TOP DEAD CENTER TRICK [Re: Moparmad] #2616144
02/02/19 08:11 PM
02/02/19 08:11 PM
BDW Offline
BDW  Offline
Need a pic
Re: TOP DEAD CENTER TRICK [Re: BDW] #2616152
02/02/19 08:28 PM
02/02/19 08:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Need a pic
Don't be the exception.
Re: TOP DEAD CENTER TRICK [Re: Moparmad] #2616156
02/02/19 08:46 PM
02/02/19 08:46 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I have used for years a simple paper ball and never have had a problem being sucked in! Valve is opening so why would suck it?
Re: TOP DEAD CENTER TRICK [Re: NANKET] #2616158
02/02/19 08:55 PM
02/02/19 08:55 PM
Near Columbus, Ohio
++MAX WEDGE++ Offline
Near Columbus, Ohio
Best question ever.
I would think the intake valve would be opened to prevent that from happening
Re: TOP DEAD CENTER TRICK [Re: ++MAX WEDGE++] #2616217
02/02/19 11:50 PM
02/02/19 11:50 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Best question ever.
Stop making sense will ya laugh2 The only way it could get sucked in is if there were no rockers on the engine twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: TOP DEAD CENTER TRICK [Re: Moparmad] #2616223
02/02/19 11:56 PM
02/02/19 11:56 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
so if it happens to be on the power stroke as he's cranking it around it won't generate a vacuum?
That TDC marks hits TDC twice and only one of the is the one you want.
Re: TOP DEAD CENTER TRICK [Re: Moparmad] #2616249
02/03/19 12:43 AM
02/03/19 12:43 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Come on, guys...The OP was trying to be helpful.
Sure, he first posted in
ALL CAPS WHICH ANNOYS MANY PEOPLE.
He was trying to be a good guy though.
Re: TOP DEAD CENTER TRICK [Re: Moparmad] #2616285
02/03/19 02:27 AM
02/03/19 02:27 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
For $12 bucks these are pretty cheap and work great. Whistle Stop TDC
Re: TOP DEAD CENTER TRICK [Re: ScottSmith_Harms] #2616292
02/03/19 02:43 AM
02/03/19 02:43 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
take a old sparkplug,beat the tip out on the bottom,weld a short piece of rod in the hole,screw in the head,turn engine by hand till it contacts the rod,mark the dampener,turn engine the other way till it hits,mark dampener,halfway between the two marks is TDC
my ladder of success is missing some rungs
Re: TOP DEAD CENTER TRICK [Re: Moparmad] #2616362
02/03/19 11:39 AM
02/03/19 11:39 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Is amazing how ppl gets in doubts still with testimonials of some other ppl who already has made it!! Myself even with a ball made of paper, somehow threated into the hole threads. WON'T BE SUCKED IN!! AS FAR VALVES ARE WORKING!
Page 1 of 3 1 2 3
