Re: TOP DEAD CENTER TRICK
[Re: Moparmad]
#2615968
02/02/19 02:15 PM
02/02/19 02:15 PM
RapidRobert
Good trick, especially when you ain't in a position to watch the #1 or #6 rockers to confirm that. & if I am confirming the dampener TDC with the screw in tool, I get the dampener to 15 BTDC then screw it in till it makes contact then I go back around CCW till it touches again (hopefully at 15 ATDC) & I repeat it once for good measure.
[Re: Pacnorthcuda]
#2615988
02/02/19 02:41 PM
02/02/19 02:41 PM
Posts: 4,952 northwest USA
NANKET
northwest USA
And what is your trick for getting the plug out when you suck it into the cylinder? Best question ever.
[Re: NANKET]
#2615992
02/02/19 02:50 PM
02/02/19 02:50 PM
RapidRobert
or pay the neighbor boy a buck to hold his finger over the hole while you move the breaker. On the plastic plug if it is shaped right to where it could not get sucked inside that'd resolve that (potential) or stick a pin in it sideways. decades ago I had a plastic piece of something fall in there & people said to fire it up & I did & no issue but it was a fairly small piece iirc.
[Re: Pacnorthcuda]
#2616000
02/02/19 03:00 PM
02/02/19 03:00 PM
Posts: 44 Texas
Moparmad
Texas
never had it happen. I put the plug in fairly loose and turn the crank with a ratchet slowly. it may suck in a little but it makes it easier to blow out. it is also important to have the right size plug. err on the side of a little too big.
I do also use the plug with the outer lip that is bigger than the insertion diameter.
[Re: Moparmad]
#2616138
02/02/19 08:03 PM
02/02/19 08:03 PM
Posts: 3,101 Michigan
A727Tflite
A clean Hemi pushrod always works when working on a Hemi.
I do t remember ever working on any car that I couldn’t bar the engine over while holding my finger over the plug hole.
[Re: Moparmad]
#2616144
02/02/19 08:11 PM
02/02/19 08:11 PM
Posts: 4,756 Florida
BDW
I do also use the plug with the outer lip that is bigger than the insertion diameter. Need a pic
[Re: BDW]
#2616152
02/02/19 08:28 PM
02/02/19 08:28 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I do also use the plug with the outer lip that is bigger than the insertion diameter. Need a pic ![](https://www.ttseries.com/wp-content/uploads/2017/01/Test-Bungs.jpg)
[Re: Moparmad]
#2616156
02/02/19 08:46 PM
02/02/19 08:46 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
I have used for years a simple paper ball and never have had a problem being sucked in! Valve is opening so why would suck it?
[Re: NANKET]
#2616158
02/02/19 08:55 PM
02/02/19 08:55 PM
Posts: 142 Near Columbus, Ohio
++MAX WEDGE++
Near Columbus, Ohio
And what is your trick for getting the plug out when you suck it into the cylinder? Best question ever. I would think the intake valve would be opened to prevent that from happening
[Re: ++MAX WEDGE++]
#2616217
02/02/19 11:50 PM
02/02/19 11:50 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
And what is your trick for getting the plug out when you suck it into the cylinder? Best question ever. I would think the intake valve would be opened to prevent that from happening Stop making sense will ya ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) The only way it could get sucked in is if there were no rockers on the engine ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Moparmad]
#2616223
02/02/19 11:56 PM
02/02/19 11:56 PM
Supercuda
About to go away
About to go away
up yours
so if it happens to be on the power stroke as he's cranking it around it won't generate a vacuum?
That TDC marks hits TDC twice and only one of the is the one you want.
[Re: ScottSmith_Harms]
#2616292
02/03/19 02:43 AM
02/03/19 02:43 AM
Posts: 954 garnett kansas
rhad
garnett kansas
take a old sparkplug,beat the tip out on the bottom,weld a short piece of rod in the hole,screw in the head,turn engine by hand till it contacts the rod,mark the dampener,turn engine the other way till it hits,mark dampener,halfway between the two marks is TDC
my ladder of success is missing some rungs
[Re: Moparmad]
#2616362
02/03/19 11:39 AM
02/03/19 11:39 AM
NachoRT74
Valencia, España
Is amazing how ppl gets in doubts still with testimonials of some other ppl who already has made it!! Myself even with a ball made of paper, somehow threated into the hole threads. WON'T BE SUCKED IN!! AS FAR VALVES ARE WORKING!
