Can I use the A833 E-body shifter location in my 1969 B-body
#2615273
01/31/19 09:09 PM
01/31/19 09:09 PM
Posts: 248 near St Petersburg, FL
Lifsgrt
Hey guys, I want to move the shifter location back for my 1969 Daytona clone I'm building for Bonneville. I want to use the short E-body style shifter lever to shorten the throws. Will the shifter linkage clear the trans crossmember, and are there any other problems caused by doing this? Thanks.
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
Re: Can I use the A833 E-body shifter location in my 1969 B-body
[Re: Lifsgrt]
#2615356
02/01/19 12:00 AM
02/01/19 12:00 AM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I use the E-body shifter location on my Savoy because it just felt better for racing. I used a Super Shifter linkage and shifter mount with that raised the shifter to go above the trans crossmember. I have a spare bracket and the forward gear linkage but you would need to get the reverse rod. I will got to my other computer and see if I still have some pics of it saved. I used the same shifter location with a 5-speed Richmond box that I ran as well. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Cab_Burge]
#2615452
02/01/19 03:25 AM
02/01/19 03:25 AM
Lifsgrt
So Gus, is the 1964 B-body the same? I think I'm ok with the shifter I have, but the only way to go above the crossmember is to have the linkage in the car with me. I was wondering if the linkage would go through the crossmember, above the trans mount, beside the transmission. Thanks. Cab, thanks for the tips on redrilling the linkage.
