Page 2 of 3 1 2 3
Re: New video testing new converter [Re: WHITEDART] #2614754
01/30/19 09:10 PM
01/30/19 09:10 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
Good luck with it luck
Re: New video testing new converter [Re: WHITEDART] #2614768
01/30/19 09:36 PM
01/30/19 09:36 PM
fullmetaljacket Offline
So I gather that the pesky Nova has been drawn back to his board to try and extract more ponies to hang 10?
Man, your Dart is just that, a Dart out of H#ll.
Re: New video testing new converter [Re: fullmetaljacket] #2614787
01/30/19 10:14 PM
01/30/19 10:14 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
thanks man I think the Nova ran for the Hills... I'm told there is a better video from the side if I can ever find it I will post it..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: New video testing new converter [Re: WHITEDART] #2614984
01/31/19 12:23 PM
01/31/19 12:23 PM
I would have to say that aside from the steam that your ride is making, it is quite impressive on the straight hook and book. It doesn't seem to like being drunk at all.
Re: New video testing new converter [Re: fullmetaljacket] #2615091
01/31/19 03:07 PM
01/31/19 03:07 PM
bean town ....Ca
W
W
bean town ....Ca
this video is from a different angle. https://youtu.be/eUmcHFbAp0w
Re: New video testing new converter [Re: WHITEDART] #2615103
01/31/19 03:15 PM
01/31/19 03:15 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
What size tire are you running could not see if it has wheels bars very impressive for sure
Re: New video testing new converter [Re: scottb] #2615108
01/31/19 03:22 PM
01/31/19 03:22 PM
bean town ....Ca
W
W
bean town ....Ca
29.5 10.5 tire . And yes the sissy sticks were on it for that pass..
Re: New video testing new converter [Re: WHITEDART] #2615269
01/31/19 09:02 PM
01/31/19 09:02 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
Originally Posted By WHITEDART
Originally Posted By cesar perez
What ET is that thing
5.30s
what's your 60'/330 on that pass?
Re: New video testing new converter [Re: racerx] #2615286
01/31/19 09:22 PM
01/31/19 09:22 PM
bean town ....Ca
W
W
bean town ....Ca
1.19 3.46 5.39
Re: New video testing new converter . Updated [Re: WHITEDART] #2615478
02/01/19 08:08 AM
02/01/19 08:08 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
upBadA$$ Dart there.
Re: New video testing new converter [Re: WHITEDART] #2615490
02/01/19 09:58 AM
02/01/19 09:58 AM
PA
Harry's Taxi 2 Offline
PA
WHITEDART, could you share with us the results of your converter test? Thank You
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: New video testing new converter [Re: Harry's Taxi 2] #2615666
02/01/19 06:14 PM
02/01/19 06:14 PM
bean town ....Ca
W
W
bean town ....Ca
. I took out a 7in converter that would flash to 7300 . And drop to 7500 on the gear change.. this converter felt very mushy and the efficiency was not very good however it was fast.. it went a 119.2 /60 ft...with a 5.42. At 126mph . And would pick up another 33 mph on the back half.. at about 15% slippage.. I had an 8-inch built looking for a little more torque multiplication and a little more efficiency. It is slightly tighter at about 7100 rmp. I think it needs to be at about 7,500.. that being said it's still went its new best at 5.39 at 127.. we still had some ET left in the tune-up unfortunately the track wasn't up to the task also if you noticed it was smoking pretty heavily.. it was pulling in a . Hefty amount of oil into the intake track my fault I got that squared away now hopefully we can get it to a good track and get the car to run what Wallace says it should run..
Re: New video testing new converter [Re: WHITEDART] #2615696
02/01/19 07:37 PM
02/01/19 07:37 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Love the Wallace! It shows me how much of an underachiever I am! LOL
Re: New video testing new converter [Re: WHITEDART] #2615700
02/01/19 07:47 PM
02/01/19 07:47 PM
PA
PA
Thanks for the explanation, I like to enhance the knowledge base when I can.
You say it dropped to 7500 on the gear change, what were you shifting at?
Re: New video testing new converter [Re: GY3] #2615701
02/01/19 07:53 PM
02/01/19 07:53 PM
iagree
None of the on line calculator agree with any other so what do you think that means confused work
The time slip and the spark plug are always the best tool to make decisions on how to go on the tune and part changes as well as watching the fastest car in your class to measure your results the same day at the same track work
Re: New video testing new converter [Re: Harry's Taxi 2] #2615705
02/01/19 08:19 PM
02/01/19 08:19 PM
bean town ....Ca
W
W
bean town ....Ca
the light is set for 8800+
Re: New video testing new converter [Re: Cab_Burge] #2615712
02/01/19 08:38 PM
02/01/19 08:38 PM
bean town ....Ca
W
W
bean town ....Ca
iagree
. Good afternoon Cab hope all is well. I understand exactly what you are saying it is just the ruler that I have been using. On this program we have been exactly on at times and off by a mile at others I understand that track conditions and altitude play into these factors.. but what I can tell you is if your car runs what Wallace says you've done a really good job in my opinion some guys run much faster
Re: New video testing new converter [Re: GY3] #2615806
02/02/19 12:44 AM
02/02/19 12:44 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I resemble that reMARK whistling
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: New video testing new converter [Re: WHITEDART] #2615869
02/02/19 04:21 AM
02/02/19 04:21 AM
michigan
6pakdakota Offline
6pakdakota  Offline
michigan
That thing gets it
Re: New video testing new converter [Re: WHITEDART] #2615948
02/02/19 01:52 PM
02/02/19 01:52 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Shiloh,
I have heard seven inch converters can be very hard on the engines thrust bearing and that if you let off and get back on one at the finish line they sort of "unhook" and you lose propulsion.
Has that been your experience?
Thank you for sharing your experience with us.
Bill
Page 2 of 3 1 2 3
