Sonic testing
#2613914
01/29/19 10:24 AM
01/29/19 10:24 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Anyone have exprience with sonic testing multi layers? As an example, if you have a sleeve in a bore, will it show the sum of the two materials, or does it read only the sleeve?
Re: Sonic testing
[Re: scatpacktom]
#2614000
01/29/19 01:25 PM
01/29/19 01:25 PM
Posts: 22,790 Bitopia
jcc
Bitopia
That was my understanding also, I suspect however it is measurable, but requires a unit (different?) tuned to a likely much lower frequency so as not to "hear" the "discontinuity", but I bet that gives up accuracy or requires a greater material thickness to measure in the first place.
Re: Sonic testing
[Re: TRENDZ]
#2615141
01/31/19 03:56 PM
01/31/19 03:56 PM
TRENDZ
Milwaukee WI
My question was general. Im not actually doing it, just wondering out loud.
