Sonic testing #2613914
01/29/19 10:24 AM
01/29/19 10:24 AM
Milwaukee WI
TRENDZ Offline OP
TRENDZ  Offline OP
Milwaukee WI
Anyone have exprience with sonic testing multi layers? As an example, if you have a sleeve in a bore, will it show the sum of the two materials, or does it read only the sleeve?
Re: Sonic testing [Re: TRENDZ] #2613920
01/29/19 10:49 AM
01/29/19 10:49 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
It will only read the sleeve
Re: Sonic testing [Re: scatpacktom] #2614000
01/29/19 01:25 PM
01/29/19 01:25 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
That was my understanding also, I suspect however it is measurable, but requires a unit (different?) tuned to a likely much lower frequency so as not to "hear" the "discontinuity", but I bet that gives up accuracy or requires a greater material thickness to measure in the first place.
Re: Sonic testing [Re: TRENDZ] #2614115
01/29/19 04:18 PM
01/29/19 04:18 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Been there, done that. It measures the sleeve. Also, since the sleeve is likely a different material than the 'gray cast' block, the readings will be off a little.
Re: Sonic testing [Re: @#$%&*!] #2614144
01/29/19 05:05 PM
01/29/19 05:05 PM
dogdays Offline
dogdays  Offline
Agreed. The discontinuity sends back a reflection. The first use for ultrasonic testing (UT) was to find internal flaws in metal, especially welds.
R.
Re: Sonic testing [Re: TRENDZ] #2615123
01/31/19 03:46 PM
01/31/19 03:46 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Can you go in through the cooling passages and measure from that side to the sleeve?
Re: Sonic testing [Re: TRENDZ] #2615141
01/31/19 03:56 PM
01/31/19 03:56 PM
Milwaukee WI
TRENDZ Offline OP
TRENDZ  Offline OP
Milwaukee WI
My question was general. Im not actually doing it, just wondering out loud.
Re: Sonic testing [Re: TRENDZ] #2615214
01/31/19 06:33 PM
01/31/19 06:33 PM
dogdays Offline
dogdays  Offline
You can do it anywhere you can set your probe at right angles resting on bare metal.
There are probes that send the sonic pulse at an angle but they are for finding cracks.
R.
