W8 head bolt pattern #2611929
01/25/19 03:56 AM
01/25/19 03:56 AM
California
slowfab Offline OP
slowfab  Offline OP
California
Does anyone have a W8 head bolt location, dimensional schematic?
Re: W8 head bolt pattern [Re: slowfab] #2612066
01/25/19 02:36 PM
01/25/19 02:36 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I don't have it but if you can find W9 they are the same as would the R3 blocks that support them.
Would a head gasket get you close enough?
What is your project? Could be interesting!
If you have not done so already you might try posting on the W7 W8 W9 pages on Facebook.
Re: W8 head bolt pattern [Re: slowfab] #2612076
01/25/19 02:55 PM
01/25/19 02:55 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
It's the same as W9, right? Gary Stanton might have something for you.
Re: W8 head bolt pattern [Re: slowfab] #2612102
01/25/19 03:36 PM
01/25/19 03:36 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I have them at work on a print. I can try to get it Monday.
Re: W8 head bolt pattern [Re: slowfab] #2612434
01/26/19 04:06 AM
01/26/19 04:06 AM
California
slowfab Offline OP
slowfab  Offline OP
California
Thanks for the help guys. I measured it out off the block. The head gaskets from Cometic are oblonged so there is not a exact spot. The project is a set of victor heads. They have tapped holes from the deck side and on center. I will post more info on the build soon. It is a Ritter block with victor heads. This will be a twin turbo build.
Re: W8 head bolt pattern [Re: slowfab] #2612477
01/26/19 11:18 AM
01/26/19 11:18 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
QMP IN CALIFORNIA has done a ton of Ritter blocks.the have a set of vic head for mach up as well one stop shop for sure
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: W8 head bolt pattern [Re: slowfab] #2612488
01/26/19 11:48 AM
01/26/19 11:48 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
Yea we are trying to get them to change the head so it works.
We have the CNC program to put holes in heads where the should be.
You have to fill in the hole in the deck as the new hole is only half into the 7/16 hole from them and it will push you mill bit off center.
Re: W8 head bolt pattern [Re: slowfab] #2612538
01/26/19 01:26 PM
01/26/19 01:26 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Brett, so the Victor head has one of the 7/16" holes in the wrong spot?
Re: W8 head bolt pattern [Re: 340Cuda] #2612606
01/26/19 03:24 PM
01/26/19 03:24 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
They did the head like a hemi
Has threaded hole in the deck and it’s on bore center line.
This is not how a R3 small block was done so I have no clue what they where doing with this head.
Re: W8 head bolt pattern [Re: W5DART66] #2612629
01/26/19 04:09 PM
01/26/19 04:09 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Yep, on the r3 18 bolt patterns,the smaller upper studs are not central to the bore..but i *think* they are on the bottom row however. I cant remember
