Re: W8 head bolt pattern
[Re: slowfab]
#2612477
01/26/19 11:18 AM
01/26/19 11:18 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Thanks for the help guys. I measured it out off the block. The head gaskets from Cometic are oblonged so there is not a exact spot. The project is a set of victor heads. They have tapped holes from the deck side and on center. I will post more info on the build soon. It is a Ritter block with victor heads. This will be a twin turbo build. QMP IN CALIFORNIA has done a ton of Ritter blocks.the have a set of vic head for mach up as well one stop shop for sure
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: W5DART66]
#2612629
01/26/19 04:09 PM
01/26/19 04:09 PM
Posts: 3,395 Pa
Hot 340
Pa
They did the head like a hemi
Has threaded hole in the deck and it’s on bore center line.
This is not how a R3 small block was done so I have no clue what they where doing with this head.
Yep, on the r3 18 bolt patterns,the smaller upper studs are not central to the bore..but i *think* they are on the bottom row however. I cant remember
