Trans techs: 98 Voyager low fluid symptom (updated) #260797
03/21/09 03:25 PM
03/21/09 03:25 PM
SoCal
68HemiB Offline OP
68HemiB  Offline OP
SoCal
1998 Grand Voyager 3.3 with 125K miles. Routine service has been done (fluid/filter changes at roughly 50k and 100k). The wife reports that intermittently the van will, from a stop sign or red light, rev and then eventually drop into gear harshly (like textbook low fluid level). Of course it will never do this for me, but I don't think she's crazy (on this point at least...). I have checked the fluid level multiple times ("don't overfill! between bottom holes warm, between top holes hot. idle in Park. don't overfill!") and it is NOT low on fluid. The fluid is not horribly dark or smelly. Looks like 25K old ATF to me (which it is).
I know enough not to expect a fluid change to help at this point (especially if the friction material suspended in the ATF is the only thing keeping this trans from complete failure).
Emotionally, I want to believe that there's a secret $20 externally-mounted flanged niblick control valve that is to blame.
Intellectually, I know that I have a transmission on the way out, and it should be rebuilt.
Is there something I'm missing here (or a secret flanged niblick valve)?
Down to just a blue car now.
Re: Trans techs: 98 Voyager low fluid symptom, NOT low [Re: 68HemiB] #260798
03/21/09 03:33 PM
03/21/09 03:33 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I thought you were supposed to check it running in neutral?
Re: Trans techs: 98 Voyager low fluid symptom, NOT low [Re: stumpy] #260799
03/21/09 03:43 PM
03/21/09 03:43 PM
SoCal
68HemiB Offline OP
68HemiB  Offline OP
SoCal
Indeed there are many transmissions (like 727's) that are that way. Been there, been bit.
Not so here. Clearly on the dipstick says IN PARK. Really.
Re: Trans techs: 98 Voyager low fluid symptom, NOT low [Re: 68HemiB] #260800
03/21/09 03:56 PM
03/21/09 03:56 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Any MIL on? A loss of prime code would pop up if you were low on fluid. Any kind of slippage would also log a code. Over fill a qt and see what happens.
Re: Trans techs: 98 Voyager low fluid symptom, NOT low [Re: SALEM1912] #260801
03/21/09 04:15 PM
03/21/09 04:15 PM
SoCal
68HemiB Offline OP
68HemiB  Offline OP
SoCal
No idiot lights, briefly or on solid.
I am very hesitant to overfill. Nothing has changed with the dipstick, the tube, or the tube's orientation. I am fairly responsible about checking fluid levels, and dipstick is registering today what it has always registered since this van was brand new. The dipstick is warning not once, but twice against overfilling. "Do Not Overfill" and "Do Not Add Fluid if between holes".
Because this is intermittent (but getting worse), overfilling and then saying "look, it's fixed" is unrealistic. Doing so will not convince my wife that the van is not about to leave her stranded somewhere (an eventuality about which she is now convinced).
Bear in mind that my low-fluid-symptom is a former mechanic's [who never earned a living on automatic transmissions] representation of his translation of his wife's description of the symptoms. Spouse insanity can be ruled out, because my mechanically savvy 13 y/o son confirms the symptoms.
Re: Trans techs: 98 Voyager low fluid symptom, NOT low [Re: 68HemiB] #260802
03/21/09 04:30 PM
03/21/09 04:30 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Over filling an auto will only make it worse, (causes foaming of the fluid)
without any kind of clutch fill volumns to confirm or deny anything I would say the front pump is loosing prime. drop the pan and make sure the filter is engaged in the valve body
If it is ,,,,,,, have fun - sounds like an overhaul is in your future
Re: Trans techs: 98 Voyager low fluid symptom, NOT low [Re: gtx6970] #260803
03/21/09 04:57 PM
03/21/09 04:57 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I have seen 604 filters fall off also we fill to hot full mark right from get go and you would have to get 1 WAY overfull befor it would cause any problems.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Trans techs: 98 Voyager low fluid symptom, NOT low [Re: dusturbd340W5] #260804
03/21/09 10:32 PM
03/21/09 10:32 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Since you are only relaying the conditions,perhaps there is a engine performance issue. How often does this happen? You may have a TPS with a worn spot, this could cause a stumble while accelerating from a stop. They don't usually leave a code.
Re: Trans techs: 98 Voyager low fluid symptom, NOT low [Re: SALEM1912] #260805
03/21/09 11:16 PM
03/21/09 11:16 PM
Lebanon ,PA in the Susquehanna...
70Challengerse Offline
The trans a-604 is to be checked in park ....the problem that you are experiencing is that it was put in gear to quick...it needs to be relearned can be done with real scanner...poss a loss of prime is the problem....
Re: Trans techs: 98 Voyager low fluid symptom, NOT low [Re: 70Challengerse] #260806
03/22/09 04:01 PM
03/22/09 04:01 PM
MINNESOTA
BRONZEBEE Offline
BRONZEBEE  Offline
MINNESOTA
check the orange o-ring on the filter,ive seen them cut or missing.
Re: Trans techs: 98 Voyager low fluid symptom, NOT low [Re: gtx6970] #260807
03/22/09 10:43 PM
03/22/09 10:43 PM
SoCal
68HemiB Offline OP
68HemiB  Offline OP
SoCal
First of all, thanks to everyone who took the time to reply.
As for a "stumble" being mis-described, I had already ruled that out between the corroboration with my son, and the description of the tachometer needle climbing when it was slipping.
So, today I dropped the pan and had a look. The magnet was fuzzier than I would have liked, and the smell of a drain pan full of used ATF is certainly more significant than a dipstick tip's worth.
Even so, I am finding some reason to be encouraged...
The o-ring was present and intact. The filter was not residing detached in the bottom of the pan. However, the fit of the filter neck into the valve body was far from firm. When I compare how the new filter feels (tight and solid) when installed, I can sure see how the old one could have been sucking air once in a while.
This finding has reinstated my wife's willingness to give the van another chance. The plan is to use it more (when gas prices peaked, we took my mother-in-law's econobox out of mothballs for trips that didn't require the van's capacity), and to put me behind the wheel most of the time. Most importantly, we are not bound in a headlong rush for the transmission shop come Monday morning.
We shall see.
Thanks again for all the suggestions
Re: Trans techs: 98 Voyager low fluid symptom, NOT low [Re: 68HemiB] #260808
03/23/09 07:36 PM
03/23/09 07:36 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
might be the trans solenold fading...
