Robert in case you wanted to know, here are the other OEM parts it should have in it. LU converter, blue-Green coded valve body with a 67 steel plate in it, a 528 transfer plate and 495 valve body, a 962 case, plain accumulator spring color, 3.2 kickdown servo lever, blue Kickdown spring, Red coded governor with narrow spool and red spring, 5 disc front clutch assembly, yellow return spring, 4 disc rear clutch assembly, 4 pinion front and rear planetary assemblies, with wide ratio.
