what yr is this 904? #2607158
01/15/19 09:00 PM
01/15/19 09:00 PM
RapidRobert Offline OP
PK4295887X 7763 9355 & eng/app if that is relevent for HD/extra discs etc. Thank you for your time.
Re: what yr is this 904? [Re: RapidRobert] #2607162
01/15/19 09:10 PM
01/15/19 09:10 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
It's a 1984 model 904 from behind a 318 Engine
Re: what yr is this 904? [Re: Joesixpack] #2607168
01/15/19 09:17 PM
01/15/19 09:17 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Re: what yr is this 904? [Re: Joesixpack] #2607170
01/15/19 09:18 PM
01/15/19 09:18 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
1983 Mirada/Cordoba and 1984-85 Chrysler 5th Avenue. 904 with 318 engine.
Re: what yr is this 904? [Re: Joesixpack] #2607171
01/15/19 09:22 PM
01/15/19 09:22 PM
informative chart. Thank you!
Re: what yr is this 904? [Re: RapidRobert] #2607177
01/15/19 09:28 PM
01/15/19 09:28 PM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
Robert in case you wanted to know, here are the other OEM parts it should have in it. LU converter, blue-Green coded valve body with a 67 steel plate in it, a 528 transfer plate and 495 valve body, a 962 case, plain accumulator spring color, 3.2 kickdown servo lever, blue Kickdown spring, Red coded governor with narrow spool and red spring, 5 disc front clutch assembly, yellow return spring, 4 disc rear clutch assembly, 4 pinion front and rear planetary assemblies, with wide ratio.
Re: what yr is this 904? [Re: Tom Hand] #2607186
01/15/19 09:37 PM
01/15/19 09:37 PM
Tom good addit'l info! I found it buried in my stash yesterday & was considering/wanting to rebuild it/race it behind this years' 360 stock car. Not sure if a LU is a good choice or not but I am assuming that it ain't.
Re: what yr is this 904? [Re: RapidRobert] #2607198
01/15/19 09:49 PM
01/15/19 09:49 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
2.74 FIRST GEAR PLANETARY ?
Re: what yr is this 904? [Re: RapidRobert] #2607769
01/16/19 10:12 PM
01/16/19 10:12 PM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
Wide ratio, yes. 2.67:1 or 2.74:1 depends on which Chrysler document you read. "
Re: what yr is this 904? [Re: Tom Hand] #2607807
01/16/19 11:14 PM
01/16/19 11:14 PM
I've seen 2.74 alot. I gotta bone up on what the LU is/does to see if this one is an appropriate candidate for my needs.
Re: what yr is this 904? [Re: RapidRobert] #2609018
01/19/19 03:56 PM
01/19/19 03:56 PM
Locomotion Offline
Locomotion  Offline
A lock-up trans will have about 3/4" of the converter end shaft machined smooth. Chances are it is a lock-up. The valve body and pump and/or front shaft has to be changed. I don't know the specifics because JW trans always did the conversion for me. There is a visual difference between 2.45 and 2.74 gear sets also. But I don't know what that is.
Converters do not interchange without the conversion.
Re: what yr is this 904? [Re: Locomotion] #2609189
01/20/19 12:26 AM
01/20/19 12:26 AM
Since a racing converter will be a critical addition, I for sure need to convert or grab another core. I got some homework to do here.
