Need help identify Mopar R3 block #2606291
01/14/19 02:49 AM
01/14/19 02:49 AM
jacksonville,FLORIDA
slammedR/T Offline OP
Need assistance to identify this block part number, told it is a Mopar R3 block.
5153477-340
Thank you.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Need help identify Mopar R3 block [Re: slammedR/T] #2606314
01/14/19 05:43 AM
01/14/19 05:43 AM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Jegs has this block listed https://www.jegs.com/webapp/wcs/stores/s...p;storeId=10001 5153477 is the casting #
Re: Need help identify Mopar R3 block [Re: slammedR/T] #2606340
01/14/19 10:18 AM
01/14/19 10:18 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
http://www.shadydellspeedshop.com/faq.htm there is some good info about the different types of blocks a little ways down the page.
68 Barracuda Formula S 340
Re: Need help identify Mopar R3 block [Re: Bad340fish] #2606444
01/14/19 02:14 PM
01/14/19 02:14 PM
Thank you for the link
racemagnum
Re: Need help identify Mopar R3 block [Re: slammedR/T] #2606531
01/14/19 05:39 PM
01/14/19 05:39 PM
Finally go pictures of the front of the block with the part number
P5153452 R3 Magnum block, I'm going to get it as it is virgin never machined and the price is right.
racemagnum
Re: Need help identify Mopar R3 block [Re: slammedR/T] #2606928
01/15/19 02:14 PM
01/15/19 02:14 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Probably a nice block but not really an race "R" block.
From the instructions:
"Magnum Race Blocks
Magnum race blocks are designed for general HP use and
entry level racing. These blocks are a heavy duty 5.2L (318)
Magnum (P5153579) or 5.9L (360) Magnum block
(P5153452)."
Certainly not inexpensive new, Jeg's shows about $3,550. Not sure if they are really available as it says to call.
Re: Need help identify Mopar R3 block [Re: slammedR/T] #2606938
01/15/19 02:30 PM
01/15/19 02:30 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
P515 should be an R3 derivative.
Go take a look and check out the filled in pan rails, main cap support, lifter bore beef and so on. Should be very R3-ish because that's the origin of the product.
The whole "magnum race block" thing is strictly marketing hoo-ha to account for a couple really minor machining variations...provisions for a magnum crank sensor mostly.
I vaguely recall a conversation with Jim S. around 2012 or so, where he said he couldn't get the magnum lifter bore spiders to work. I am pretty sure that aspect of them is not very "magnum" at all.
