Stuck strut rods - suggestions welcome. #2605897
01/13/19 02:48 PM
01/13/19 02:48 PM
Connecticut, USA
MRGTX Offline OP
MRGTX  Offline OP
Connecticut, USA
I’m getting ready to install QA1 dynamic strut rods...
Ran into a problem in getting the factory rods out. I torqued down the nut on the control arm side of the stock rods and no matter what I do, trying to loosen the p nut on the K member side just spins the whole rod. I’ve soaked them with penetrating oil, I’ve heated them with a torch...no luck.
Any ideas?
Re: Stuck strut rods - suggestions welcome. [Re: MRGTX] #2605902
01/13/19 03:06 PM
01/13/19 03:06 PM
AndyF Offline
AndyF  Offline
Clamp a vise on there.
Re: Stuck strut rods - suggestions welcome. [Re: MRGTX] #2605959
01/13/19 04:45 PM
01/13/19 04:45 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Tried an impact yet?
Re: Stuck strut rods - suggestions welcome. [Re: MRGTX] #2606010
01/13/19 06:01 PM
01/13/19 06:01 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
did you take the roll pin out? Joke, you don't mention an impact, sometimes that'll shock it enough to break it free. A strap wrench if you don;t want to mar the surface of the rod. IF you are going to scrap them a long pipe wrench on the rod and the handle on the ground so that the ground will keep it from turning on you.
Don't be the exception.
Re: Stuck strut rods - suggestions welcome. [Re: MRGTX] #2606141
01/13/19 09:39 PM
01/13/19 09:39 PM
Connecticut, USA
MRGTX Offline OP
MRGTX  Offline OP
Connecticut, USA
Thanks for all of the responses, guys.
I tried the vice grip idea again but since I’m not saving the rod, i decided to grind flat spots in the rod to give the grips better purchase and that did the trick.
I don’t know what was going on in the fall of 1972 when my car was being assembled but I gather that the Hamtramck cafeteria was serving Wheaties that day!
Re: Stuck strut rods - suggestions welcome. [Re: MRGTX] #2606160
01/13/19 10:08 PM
01/13/19 10:08 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Oh, I suspect that 47 years of Connecticut winters may have played a role in this as well.
Re: Stuck strut rods - suggestions welcome. [Re: MRGTX] #2606170
01/13/19 10:22 PM
01/13/19 10:22 PM
Los Osos, Ca
CKessel Online content
CKessel  Online Content
Los Osos, Ca
Time for a Victor wrench aka torch.
Carl Kessel
Re: Stuck strut rods - suggestions welcome. [Re: CKessel] #2606180
01/13/19 10:50 PM
01/13/19 10:50 PM
Conroe , Texas
I
iapco103 Offline
iapco103  Offline
I
Conroe , Texas
aka the blue wrench Paul
Re: Stuck strut rods - suggestions welcome. [Re: Kern Dog] #2606221
01/13/19 11:59 PM
01/13/19 11:59 PM
Connecticut, USA
MRGTX Offline OP
MRGTX  Offline OP
Connecticut, USA
As far as I know, this car has never been on the road for a CT winter day. It came from North Carolina and evidently didn’t get driven much when the original owner moved up here. I bought it from him when I was 17 and worshipped it...and I was happy to go car-less in the winters to keep my machine clean and rust-free. That was 23 years ago. So far, so good. smile
Re: Stuck strut rods - suggestions welcome. [Re: MRGTX] #2606229
01/14/19 12:30 AM
01/14/19 12:30 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The strut rod has a slight interference fit into the control arm. If it spins fully seated there isn't enough interference.
Re: Stuck strut rods - suggestions welcome. [Re: Jim_Lusk] #2606457
01/14/19 02:27 PM
01/14/19 02:27 PM
Connecticut, USA
MRGTX Offline OP
MRGTX  Offline OP
Connecticut, USA
Thanks, Jim.
Now that you mention it, that makes sense. This would presumably be designed into the system to avoid the situation that I ran into.
FWIW, These were stock strut rods in QA1 LCAs. I'll keep the interference fit in mind when I install the QA1 dynamic rods this week.
Re: Stuck strut rods - suggestions welcome. [Re: MRGTX] #2606608
01/14/19 08:42 PM
01/14/19 08:42 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Wasn't someone having issues with aftermarket LCA pivots being undersized? I forget which brand, might have been QA1.
Re: Stuck strut rods - suggestions welcome. [Re: MRGTX] #2606610
01/14/19 08:44 PM
01/14/19 08:44 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Found the thread
LCA pivot issue
