Stuck strut rods - suggestions welcome.
#2605897
01/13/19 02:48 PM
01/13/19 02:48 PM
Posts: 111 Connecticut, USA
MRGTX
Connecticut, USA
I’m getting ready to install QA1 dynamic strut rods...
Ran into a problem in getting the factory rods out. I torqued down the nut on the control arm side of the stock rods and no matter what I do, trying to loosen the p nut on the K member side just spins the whole rod. I’ve soaked them with penetrating oil, I’ve heated them with a torch...no luck.
Any ideas?
Re: Stuck strut rods - suggestions welcome.
[Re: MRGTX]
#2605902
01/13/19 03:06 PM
01/13/19 03:06 PM
Posts: 31,037 Oregon
AndyF
[Re: MRGTX]
#2606010
01/13/19 06:01 PM
01/13/19 06:01 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
did you take the roll pin out? Joke, you don't mention an impact, sometimes that'll shock it enough to break it free. A strap wrench if you don;t want to mar the surface of the rod. IF you are going to scrap them a long pipe wrench on the rod and the handle on the ground so that the ground will keep it from turning on you.
[Re: MRGTX]
#2606141
01/13/19 09:39 PM
01/13/19 09:39 PM
MRGTX
Connecticut, USA
Thanks for all of the responses, guys.
I tried the vice grip idea again but since I’m not saving the rod, i decided to grind flat spots in the rod to give the grips better purchase and that did the trick.
I don’t know what was going on in the fall of 1972 when my car was being assembled but I gather that the Hamtramck cafeteria was serving Wheaties that day!
[Re: MRGTX]
#2606170
01/13/19 10:22 PM
01/13/19 10:22 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
Time for a Victor wrench aka torch.
Carl Kessel
[Re: MRGTX]
#2606608
01/14/19 08:42 PM
01/14/19 08:42 PM
Supercuda
About to go away
About to go away
up yours
Wasn't someone having issues with aftermarket LCA pivots being undersized? I forget which brand, might have been QA1.
[Re: MRGTX]
#2606610
01/14/19 08:44 PM
01/14/19 08:44 PM
Supercuda
About to go away
About to go away
up yours
Found the thread LCA pivot issue
