where to purchase 2" 90* mandrel bends ? #2605979
01/13/19 05:07 PM
01/13/19 05:07 PM
moparx Offline OP
moparx  Offline OP
where is the best place to purchase 2" mandrel bends to repair mashed sections of a set of TTI headers ?
without cutting these apart, are these made from 16ga, or 14ga tube ?
as always, TIA bow
beer
Re: where to purchase 2" 90* mandrel bends ? [Re: moparx] #2606001
01/13/19 05:38 PM
01/13/19 05:38 PM
P
Porter67 Offline
Porter67  Offline
P
Linkie...
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=2%22+mandrel+bends&_sacat=0
Re: where to purchase 2" 90* mandrel bends ? [Re: Porter67] #2606071
01/13/19 07:36 PM
01/13/19 07:36 PM
moparx Offline OP
moparx  Offline OP
thanks ! i looked on the bag, but i must have been too specific on what i was looking for, as your link has a much better selection.
any idea how thick TTI pipes are ?
beer
Re: where to purchase 2" 90* mandrel bends ? [Re: moparx] #2606075
01/13/19 07:51 PM
01/13/19 07:51 PM
Re: where to purchase 2" 90* mandrel bends ? [Re: moparx] #2606163
01/13/19 10:10 PM
01/13/19 10:10 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I don't think it would be that critical to match up pipe thickness. But more than likely 16 ga. Speedway has a u bend with a 90 for $15. 16 ga.
Re: where to purchase 2" 90* mandrel bends ? [Re: moparx] #2606193
01/13/19 11:07 PM
01/13/19 11:07 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
burns stainless, nice stuff, actually real nice stuff
https://burnsstainless.com/collections/tubing
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: where to purchase 2" 90* mandrel bends ? [Re: moparx] #2606228
01/14/19 12:29 AM
01/14/19 12:29 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Autozone has 90 degree 2" bends for 7.99. I used some recently to recreate a fuel tank filler tube. This is from Oreilly, but the one I got looked like it. It didn't have the crushed tube look that these 90 degree bends had in the past.
Re: where to purchase 2" 90* mandrel bends ? [Re: Exit1965] #2606307
01/14/19 03:32 AM
01/14/19 03:32 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
he asked for mandrel bent, that is just bent and it necks down...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: where to purchase 2" 90* mandrel bends ? [Re: moparx] #2606367
01/14/19 11:38 AM
01/14/19 11:38 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Woolf Aircraft. They will have anything you need.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: where to purchase 2" 90* mandrel bends ? [Re: moparx] #2606372
01/14/19 11:57 AM
01/14/19 11:57 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Woolf most likely will but, beware ..their shipping charges are out of this world .
I bought an 13 dollar item , shipping was $40.00 , ground UPS
Did not ask that question so I'm dumb
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: where to purchase 2" 90* mandrel bends ? [Re: bigdad] #2606410
01/14/19 01:15 PM
01/14/19 01:15 PM
moparx Offline OP
moparx  Offline OP
great info guys ! thanks !
dad, you bring up a good point about shipping charges. most of the time, i calculate that into the equation. sometimes, an item can be cheaper by being more expensive with less shipping, than the same item costing less, but charging more to ship.
that speedway U + 90 might be the way to go. i need to repair 6 pipes just off the flange at where they start to turn. the speedway pipe basically having three 90's, i can use both sides of the bend, since i only require approximately a 1 3/4" long section to splice into each pipe to be repaired.
i believe these pipes were made for angle plug heads [which i have], and the PO used [or tried to] them on straight plug heads, hence the mashed tubes.
thanks again for all the replies ! i will be able to repair these, then send them out to get coated.
beer
Re: where to purchase 2" 90* mandrel bends ? [Re: moparx] #2606418
01/14/19 01:29 PM
01/14/19 01:29 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I am local so I never asked them any shipping charges. I did not know it was so high.
Re: where to purchase 2" 90* mandrel bends ? [Re: 6PKRTSE] #2606472
01/14/19 03:16 PM
01/14/19 03:16 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
I usually buy them from Summit. I get them in raw finish so you aren't dealing with the aluminized coating. Hooker or Dynatech are usually the most affordable brands.
Edit: I buy a J bend and cut out the angle I want...
Re: where to purchase 2" 90* mandrel bends ? [Re: moparx] #2606498
01/14/19 04:16 PM
01/14/19 04:16 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I order online like Forest does, jegs or summit.
Rich H.
Esse Quam Videri
Re: where to purchase 2" 90* mandrel bends ? [Re: ZIPPY] #2606901
01/15/19 01:31 PM
01/15/19 01:31 PM
moparx Offline OP
moparx  Offline OP
raw is the material of choice, since they will be coated when done.
welding the aluminized material is a pain.
beer
Re: where to purchase 2" 90* mandrel bends ? [Re: moparx] #2606992
01/15/19 04:12 PM
01/15/19 04:12 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
If only looking for mild steel to then coat later once done. Schoenfeld have very inexpensive mandrel bends. A lot of dirt track roundy round guys use their tubing. I did my entire 3-1/2" with X Pipe dual exhaust with their bends & some straight pipe to the mufflers & then reduced it down to 3" up over the axle back thru the stock tips for less then $200.00 on my car.
Re: where to purchase 2" 90* mandrel bends ? [Re: moparx] #2607213
01/15/19 10:09 PM
01/15/19 10:09 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Re: where to purchase 2" 90* mandrel bends ? [Re: DrCharles] #2607515
01/16/19 03:06 PM
01/16/19 03:06 PM
moparx Offline OP
moparx  Offline OP
Originally Posted By DrCharles
there are lots of things there. thanks doc ! [NOT to be confused with dOC ! biggrin]
beer
Re: where to purchase 2" 90* mandrel bends ? [Re: moparx] #2607742
01/16/19 09:22 PM
01/16/19 09:22 PM
CA
crackedback Offline
crackedback  Offline
CA
Mandrelbends aka Columbia is really good!
Re: where to purchase 2" 90* mandrel bends ? [Re: moparx] #2608018
01/17/19 12:36 PM
01/17/19 12:36 PM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
You need to know the bend radius as well. To match the existing tubes.
