Re: where to purchase 2" 90* mandrel bends ?
[Re: Exit1965]
#2606307
01/14/19 03:32 AM
01/14/19 03:32 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Autozone has 90 degree 2" bends for 7.99. I used some recently to recreate a fuel tank filler tube. This is from Oreilly, but the one I got looked like it. It didn't have the crushed tube look that these 90 degree bends had in the past. he asked for mandrel bent, that is just bent and it necks down...
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: moparx]
#2606367
01/14/19 11:38 AM
01/14/19 11:38 AM
Posts: 4,570 Motor City
6PKRTSE
Motor City
Woolf Aircraft. They will have anything you need.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: moparx]
#2606372
01/14/19 11:57 AM
01/14/19 11:57 AM
Posts: 34,928 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Woolf most likely will but, beware ..their shipping charges are out of this world .
I bought an 13 dollar item , shipping was $40.00 , ground UPS
Did not ask that question so I'm dumb
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#2606410
01/14/19 01:15 PM
01/14/19 01:15 PM
Posts: 19,485 north of coder
moparx
great info guys ! thanks ! dad, you bring up a good point about shipping charges. most of the time, i calculate that into the equation. sometimes, an item can be cheaper by being more expensive with less shipping, than the same item costing less, but charging more to ship. that speedway U + 90 might be the way to go. i need to repair 6 pipes just off the flange at where they start to turn. the speedway pipe basically having three 90's, i can use both sides of the bend, since i only require approximately a 1 3/4" long section to splice into each pipe to be repaired. i believe these pipes were made for angle plug heads [which i have], and the PO used [or tried to] them on straight plug heads, hence the mashed tubes. thanks again for all the replies ! i will be able to repair these, then send them out to get coated.
[Re: moparx]
#2606418
01/14/19 01:29 PM
01/14/19 01:29 PM
6PKRTSE
Motor City
I am local so I never asked them any shipping charges. I did not know it was so high.
[Re: 6PKRTSE]
#2606472
01/14/19 03:16 PM
01/14/19 03:16 PM
Posts: 916 SE Washington
Forest
SE Washington
I usually buy them from Summit. I get them in raw finish so you aren't dealing with the aluminized coating. Hooker or Dynatech are usually the most affordable brands.
Edit: I buy a J bend and cut out the angle I want...
[Re: moparx]
#2606498
01/14/19 04:16 PM
01/14/19 04:16 PM
Posts: 17,880 S.E. Michigan
ZIPPY
S.E. Michigan
I order online like Forest does, jegs or summit.
Rich H.
Esse Quam Videri
[Re: moparx]
#2606992
01/15/19 04:12 PM
01/15/19 04:12 PM
6PKRTSE
Motor City
If only looking for mild steel to then coat later once done. Schoenfeld have very inexpensive mandrel bends. A lot of dirt track roundy round guys use their tubing. I did my entire 3-1/2" with X Pipe dual exhaust with their bends & some straight pipe to the mufflers & then reduced it down to 3" up over the axle back thru the stock tips for less then $200.00 on my car.
