Milodon External oil system simple Q: #2604497
01/10/19 04:56 PM
01/10/19 04:56 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
What kind of hose does everyone use, regular braided hose or teflon lined?
This doesn't seem like an application where Teflon would normally be used, but thought I would ask.
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2604502
01/10/19 05:03 PM
01/10/19 05:03 PM
Teflon would be my choice, if you can use it without kinking it up
I've use the braided black vito lined Fragola hose and fittings also for the pickup side up That hose is easier to use and make, except for getting it pushed on all the way on the fittings whiney Boiling water is your friend for assembling them up scope
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2604503
01/10/19 05:04 PM
01/10/19 05:04 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Talk with Chuck over at Best - he makes some real nice hoses for the suction side - they also put a coil spring inside the line to prevent collapse
Re: Milodon External oil system simple Q: [Re: DoubleD] #2604509
01/10/19 05:12 PM
01/10/19 05:12 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I'll be following this post closely. I will have my 572 completed shortly and while its on the stand I will shoemaker a couple of lines on it so I can test prime the oiling system before I glue the intake manifold on. Then I will have to bolt the engine in my Duster to finish the oiling system as its a little tight with the heads-up rules. I like those lines from Chuck. That looks like a nice set-up. I won't chance making my own lines for this one as I like the security of crimped lines.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Milodon External oil system simple Q: [Re: Cab_Burge] #2604525
01/10/19 05:38 PM
01/10/19 05:38 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Same here. Fragola on almost all of my stuff. As Cab Burge said "I've use the braided black vito lined Fragola hose and fittings also for the pickup side".
I also added some heat wrap due to how close mine come to the #1 tube due to modifying it for the rack & steering shaft
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2604545
01/10/19 06:21 PM
01/10/19 06:21 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Okay, thx for replies. Synthetic rubber/viton lined is acceptable, then.
I think I could probably use the teflon since it's a pretty straight shot in my application, but it seems more difficult to work with.
Will go with the regular stuff for now and see how I like it.
Thanks again.
Rich H.
Esse Quam Videri
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2604563
01/10/19 07:18 PM
01/10/19 07:18 PM
an8sec70cuda Offline
I've always just used the normal braided steel hose. Nothing special and never had any issues w/ it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2604578
01/10/19 07:38 PM
01/10/19 07:38 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Steel braided here. Teflon will work too. It's easy to put ends on.
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2604587
01/10/19 07:56 PM
01/10/19 07:56 PM
gregsdart Offline
gregsdart  Offline
I use steel braided. Examine your fittings to see if the one giong into the pan is too
Long creating a restriction. I had to trim mine quite a bit.
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2604595
01/10/19 08:18 PM
01/10/19 08:18 PM
AndyF Offline
AndyF  Offline
These days I only use the Aeroquip StartLite hose. Much easier to work with than steel braided and is more flexible. Should be fine in that application and easy to build. Cut it to length and screw on the fittings.
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2604603
01/10/19 08:34 PM
01/10/19 08:34 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
I have braided line with GOOD fittings.
Might want to check vibrant line the -6 has a higher PSI rating then most others I would guess the -12 would be the same .
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2604648
01/10/19 09:38 PM
01/10/19 09:38 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Standard steel braided on mine. Going on year 7.
Doug
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2604652
01/10/19 09:45 PM
01/10/19 09:45 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I used a rigid tube..
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2604654
01/10/19 09:50 PM
01/10/19 09:50 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
All steel now,but when it comes time to start replacing I'm thinking the cotton braid to save more weight work
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2604667
01/10/19 10:33 PM
01/10/19 10:33 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Regular braided is fine for that application.
Only thing we used Teflon on is fuel since we run alcohol. That being said we have used regular braided for alcohol fuel lines also. Just feel better about the Teflon in that situation now.
Re: Milodon External oil system simple Q: [Re: cl440] #2604684
01/10/19 11:00 PM
01/10/19 11:00 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
here is my single line set-up looped up and over never had a priming problem
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2605337
01/12/19 12:04 PM
01/12/19 12:04 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
15+ years using std braided hosing in that application with no issues.
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2605344
01/12/19 12:47 PM
01/12/19 12:47 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
For those running a Milodon system with the external adjustable relief. Anyone have a starting point as to how many turns to initially set it at? Thanks.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Milodon External oil system simple Q: [Re: ZIPPY] #2605390
01/12/19 02:20 PM
01/12/19 02:20 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I know my stock pump without adjustable valve primed up at over 100 psi. I'd probably put 1 turn from flush on it and prime it with a drill. You don't need to be running the engine with an unknown oil pressure.
Re: Milodon External oil system simple Q: [Re: sgcuda] #2605769
01/13/19 08:58 AM
01/13/19 08:58 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
What he said, I've swapped my oiling system between engines and had to adjust accordingly. KB and Indy blocks oil pathways, clearance differences etc will likely mean a change in pressure so each engine will indicate different pressures. I use the same electric drill and set the pressure at 60psi on the stand and we're good to go.
