Re: Milodon External oil system simple Q:
[Re: ZIPPY]
#2604502
01/10/19 05:03 PM
01/10/19 05:03 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Teflon would be my choice, if you can use it without kinking it I've use the braided black vito lined Fragola hose and fittings also for the pickup side That hose is easier to use and make, except for getting it pushed on all the way on the fittings Boiling water is your friend for assembling them
[Re: DoubleD]
#2604509
01/10/19 05:12 PM
01/10/19 05:12 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Talk with Chuck over at Best - he makes some real nice hoses for the suction side - they also put a coil spring inside the line to prevent collapse I'll be following this post closely. I will have my 572 completed shortly and while its on the stand I will shoemaker a couple of lines on it so I can test prime the oiling system before I glue the intake manifold on. Then I will have to bolt the engine in my Duster to finish the oiling system as its a little tight with the heads-up rules. I like those lines from Chuck. That looks like a nice set-up. I won't chance making my own lines for this one as I like the security of crimped lines.
[Re: Cab_Burge]
#2604525
01/10/19 05:38 PM
01/10/19 05:38 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
Teflon would be my choice, if you can use it without kinking it I've use the braided black vito lined Fragola hose and fittings also for the pickup side That hose is easier to use and make, except for getting it pushed on all the way on the fittings Boiling water is your friend for assembling them Same here. Fragola on almost all of my stuff. As Cab Burge said "I've use the braided black vito lined Fragola hose and fittings also for the pickup side". I also added some heat wrap due to how close mine come to the #1 tube due to modifying it for the rack & steering shaft
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: ZIPPY]
#2604545
01/10/19 06:21 PM
01/10/19 06:21 PM
Posts: 17,876 S.E. Michigan
ZIPPY
S.E. Michigan
Okay, thx for replies. Synthetic rubber/viton lined is acceptable, then.
I think I could probably use the teflon since it's a pretty straight shot in my application, but it seems more difficult to work with.
Will go with the regular stuff for now and see how I like it.
Thanks again.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2604563
01/10/19 07:18 PM
01/10/19 07:18 PM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
I've always just used the normal braided steel hose. Nothing special and never had any issues w/ it.
[Re: ZIPPY]
#2604587
01/10/19 07:56 PM
01/10/19 07:56 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I use steel braided. Examine your fittings to see if the one giong into the pan is too Long creating a restriction. I had to trim mine quite a bit.
[Re: cl440]
#2604684
01/10/19 11:00 PM
01/10/19 11:00 PM
dartman366
Mt. Vernon, Ohio
here is my single line set-up looped up and over never had a priming problem
[Re: ZIPPY]
#2605337
01/12/19 12:04 PM
01/12/19 12:04 PM
Posts: 2,926 A shed in England
Tig
A shed in England
15+ years using std braided hosing in that application with no issues.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: ZIPPY]
#2605344
01/12/19 12:47 PM
01/12/19 12:47 PM
Posts: 326 Alberta
Wookie316
Alberta
For those running a Milodon system with the external adjustable relief. Anyone have a starting point as to how many turns to initially set it at? Thanks.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: sgcuda]
#2605769
01/13/19 08:58 AM
01/13/19 08:58 AM
Tig
A shed in England
I know my stock pump without adjustable valve primed up at over 100 psi. I'd probably put 1 turn from flush on it and prime it with a drill. You don't need to be running the engine with an unknown oil pressure. What he said, I've swapped my oiling system between engines and had to adjust accordingly. KB and Indy blocks oil pathways, clearance differences etc will likely mean a change in pressure so each engine will indicate different pressures. I use the same electric drill and set the pressure at 60psi on the stand and we're good to go.
