Any tips for reapplication of horn pad silver paint accents? #2602017
01/05/19 07:00 PM
01/05/19 07:00 PM
Hamtramck, PA
Alaskan_TA Offline OP
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Like so;
Re: Any tips for reapplication of horn pad silver paint accents? [Re: Alaskan_TA] #2602044
01/05/19 07:58 PM
01/05/19 07:58 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
I did one once by using a brush about the width the channel and held a piece of note card along the inside to run the brush along and act as a shield. There were a couple places where I touched the outside and had to wipe it out. You have to keep a fair amount of paint on the brush so it doesn't look brushed.
If I had to do it again I think I would tape it up and spray. You could put the piece of tape at the bottom of the channel and run the inside fairly easily, the outside wouldn't be bad on the flat spots but you would probably have to do some x-acto work in the corners.
Mike Afflerbach
Re: Any tips for reapplication of horn pad silver paint accents? [Re: Alaskan_TA] #2602053
01/05/19 08:10 PM
01/05/19 08:10 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Thanks Mike.
The only thing that has come to me to possibly try so far is a small brush on the inside of a small diameter tube, like a small straw.
Re: Any tips for reapplication of horn pad silver paint accents? [Re: Alaskan_TA] #2602140
01/05/19 09:38 PM
01/05/19 09:38 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I've done a few using a 1/16" square tip brush. I use Testors Argent silver from the hobby store.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Any tips for reapplication of horn pad silver paint accents? [Re: Alaskan_TA] #2602237
01/05/19 11:17 PM
01/05/19 11:17 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Drip some paint in the groove and tilt the part and watch the paint run it's course.
Re: Any tips for reapplication of horn pad silver paint accents? [Re: MO_PA] #2602259
01/06/19 12:15 AM
01/06/19 12:15 AM
Ashland City, Tennessee
Aar1064 Offline
Aar1064  Offline
This is what I did but I used a hyperdermic needle to apply the paint. Takes a little time but if you watch the flow and keep it tilted so it flows down you should be fine. I used VHT Ford Argent wheel paint bought at a parts house. Just spray paint as needed in a small cup and load it up.
Re: Any tips for reapplication of horn pad silver paint accents? [Re: Aar1064] #2602361
01/06/19 11:47 AM
01/06/19 11:47 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Nice Job!
Re: Any tips for reapplication of horn pad silver paint accents? [Re: larry4406] #2602605
01/06/19 09:33 PM
01/06/19 09:33 PM
Aar1064 Offline
Aar1064  Offline
Nice Job!
Thanks. Fun stuff.
Re: Any tips for reapplication of horn pad silver paint accents? [Re: Alaskan_TA] #2602728
01/07/19 01:34 AM
01/07/19 01:34 AM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
Go buy a silver paint stick. tip is about the same width. You can get in multiple color. i use white on lettering on stuff.
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
