Any tips for reapplication of horn pad silver paint accents?
#2602017
01/05/19 07:00 PM
01/05/19 07:00 PM
Posts: 29,650 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Re: Any tips for reapplication of horn pad silver paint accents?
[Re: MO_PA]
#2602259
01/06/19 12:15 AM
01/06/19 12:15 AM
Posts: 282 Ashland City, Tennessee
Aar1064
Drip some paint in the groove and tilt the part and watch the paint run it's course. This is what I did but I used a hyperdermic needle to apply the paint. Takes a little time but if you watch the flow and keep it tilted so it flows down you should be fine. I used VHT Ford Argent wheel paint bought at a parts house. Just spray paint as needed in a small cup and load it up.
[Re: Aar1064]
#2602361
01/06/19 11:47 AM
01/06/19 11:47 AM
Posts: 519 Virginia
larry4406
Virginia
Drip some paint in the groove and tilt the part and watch the paint run it's course. This is what I did but I used a hyperdermic needle to apply the paint. Takes a little time but if you watch the flow and keep it tilted so it flows down you should be fine. I used VHT Ford Argent wheel paint bought at a parts house. Just spray paint as needed in a small cup and load it up. Nice Job!
[Re: larry4406]
#2602605
01/06/19 09:33 PM
01/06/19 09:33 PM
Aar1064
Drip some paint in the groove and tilt the part and watch the paint run it's course. This is what I did but I used a hyperdermic needle to apply the paint. Takes a little time but if you watch the flow and keep it tilted so it flows down you should be fine. I used VHT Ford Argent wheel paint bought at a parts house. Just spray paint as needed in a small cup and load it up. Nice Job! Thanks. Fun stuff.
[Re: Alaskan_TA]
#2602728
01/07/19 01:34 AM
01/07/19 01:34 AM
Posts: 1,401 northeast ohio
hulmule
northeast ohio
Go buy a silver paint stick. tip is about the same width. You can get in multiple color. i use white on lettering on stuff.
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
