Need a roller cam recommendation for my Hemi #2600133
01/01/19 09:24 PM
01/01/19 09:24 PM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
Putting together a 433 Hemi for my mostly street 64 Plymouth. Running stock 64 aluminum cross ram and carbs. 10.5 compression Stage 5 heads with .280 valve to valve clearance. What mechanical roller would work well. Tried a 320 duration .650 lift that I had laying around, and had valve to valve issues. What do you have laying around that would work?
Re: Need a roller cam recommendation for my Hemi [Re: farmboy] #2600176
01/01/19 10:10 PM
01/01/19 10:10 PM
Washington
madscientist Offline
Washington
I would call Cam Motion or let Dwayne Porter hook you up with a grind. No way would I do an off the shelf grind. I'm surprised that even today, so many guys still want to open a catalog and buy a cam. Just not my favorite thing to do.
You can also call...
Bullet
Mike Jones
Re: Need a roller cam recommendation for my Hemi [Re: farmboy] #2600202
01/01/19 10:40 PM
01/01/19 10:40 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Indy has good profiles in there catalog.
Check it out
Re: Need a roller cam recommendation for my Hemi [Re: farmboy] #2600328
01/02/19 08:33 AM
01/02/19 08:33 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Try Bullet and the more info you can give them the better the outcome will be. $.02
Re: Need a roller cam recommendation for my Hemi [Re: farmboy] #2600336
01/02/19 10:09 AM
01/02/19 10:09 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Scott Brown. Buyracingparts.com He has a cam recommendation sheet online. He's never steered me wrong.
Re: Need a roller cam recommendation for my Hemi [Re: farmboy] #2600623
01/02/19 08:52 PM
01/02/19 08:52 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Porter would be my choice after doing my homework and have 5 different grinds from 8 different opinions............... scope
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Need a roller cam recommendation for my Hemi [Re: farmboy] #2600642
01/02/19 09:28 PM
01/02/19 09:28 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Dont forget MoparRich...he has built a lot of Hemi's too. I used his recommendation to have crane build me one. My 572 is only 9.5 to 1 so we used a wide lobe separation angle, 628 lift and only 242@50 ish cam, mild street, good idle, EFI compatible. Pushrod oiling, 66550-16 lifters, stageV rockers, Dechellies top fuel shafts, Comp 959 springs, crower lash caps... Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Need a roller cam recommendation for my Hemi [Re: farmboy] #2600678
01/02/19 10:24 PM
01/02/19 10:24 PM
The valve interference during the over lap at TDC is the cam causing that, you can put less duration at .050 in it to cure that thumbs
On your deal I would look at a cam with between 255 @.050 to around 266@.050 on both lobes with as much lobe lift that you can get and have it ground on 110 to 112 LSA and installed it from 3 to 6 degrees advanced on the intake lobes scope twocents
Re: Need a roller cam recommendation for my Hemi [Re: Cab_Burge] #2600686
01/02/19 10:46 PM
01/02/19 10:46 PM
wappinger falls new york
Jimi_Vignogna Offline
Very good choice cab IMO , as with all long runner applications I would have 4 more degrees of duration on the intake lobe. And no real need to go over .625” lift. Just stressing out the valve train and will gain very little hp improvement. A 112 cam will help with intake manifold vacuum.
I would call bullet cams , great products and quick turnaround on custom ground pieces.
Re: Need a roller cam recommendation for my Hemi [Re: farmboy] #2600767
01/03/19 01:29 AM
01/03/19 01:29 AM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
I appreciate all the good information. I have had some Max wedge cars, that ran well on the street. Can you build a cross ram hemi with street manners?
Re: Need a roller cam recommendation for my Hemi [Re: fbs63] #2600815
01/03/19 07:59 AM
01/03/19 07:59 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
iagree
Re: Need a roller cam recommendation for my Hemi [Re: farmboy] #2600869
01/03/19 12:14 PM
01/03/19 12:14 PM
an8sec70cuda Offline
Dwayne Porter (Fast68plymouth) for sure! He spec'd the one in my 572 hemi.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Need a roller cam recommendation for my Hemi [Re: farmboy] #2601080
01/03/19 07:17 PM
01/03/19 07:17 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
cant go wrong with Scott Brown or Porter, they have a LOT of experience with Mopars.
I have been using Scott for a long time now, and even BES agreed with his latest cam that's in my RB, ( I figured they would want to change it )
....BAD A$$ STREET CAR.....
Re: Need a roller cam recommendation for my Hemi [Re: farmboy] #2601472
01/04/19 02:19 PM
01/04/19 02:19 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Mine is just a little ole Billet 55MM Roller custom nitrous grind cam. Made great power even on motor on the dyno for a pump gas street car.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
