Need schooling on Eddy Hemi heads #2598707
12/30/18 08:39 AM
12/30/18 08:39 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Hey guys,
What would need changing out on a 426-1 headed 572 Hemi if I were to swap to the Edelbrock heads? Has anyone gone from Indy 426-1s to the Eddy Victor heads?
i. plug tube lengths the same?
ii. piston valve relief due to the rotated exh valve ?
iii. TTI headers bolt up the same ?
iv. Stage V rollers ?
v. 3/8" OD pushrod clearance issues ?
vi. can I keep the current Indy valley tray ?
Anything else I may have missed feel free to chime in
Thanx
Re: Need schooling on Eddy Hemi heads [Re: LAD 524] #2598772
12/30/18 01:39 PM
12/30/18 01:39 PM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
Lets see
i. the plug tubes are standard HEMI length - I run the mopar ones
ii. depending on your existing piston you may have interference as the intake valve is larger and the exhaust valve is rotated - if you have a low compression piston maybe - but you would need check it - on my 572 I have a custom CP piston at 13-1 made for the eddie heads - I think Diamond has a piston also
iii. TTI 2 1/4"headers fit on my early B no issues
iv. Stage V rollers should be no issue - but may require the use of a wider (and heavier)lash cap - I use went with the Barton rollers
v. 3/8 push rod is no problem - I run a 7/16 tapered - the vic jr. heads have a pushrod tube
vi. I do not believe the Indy valley tray will work with the Eddie Jr. heads - as they are made to utilize the china rails with the intake - I run a stage V intake
The heads flow about 430 out of the box with just a little clean-up - not much room on these to improve much above that. I would get them bare with valves and add the springs of your choice. heck of a good price for heads at this level of performance.
Re: Need schooling on Eddy Hemi heads [Re: LAD 524] #2598805
12/30/18 02:39 PM
12/30/18 02:39 PM
San Diego CA
65 Hemi Offline
65 Hemi  Offline
San Diego CA
Larry Smith just posted this on FB direct Connected Mopar page.
A7AFE2D2-2C46-4A2A-834C-2FE992584AE8.jpeg503D70AB-41C9-44F0-A920-E8C6468D6063.jpegE946259A-9E33-47A5-B8DD-7CE37A428D38.jpeg29560A99-4AC3-46D6-8ED4-A13A554A2271.jpeg
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: Need schooling on Eddy Hemi heads [Re: 65 Hemi] #2598813
12/30/18 02:53 PM
12/30/18 02:53 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
One of the valves in the E-heads is rotated. Depending on cam, compression, bore size, you might need to notch your pistons. Other than that, We like them a lot. Best head out there for the money.
Re: Need schooling on Eddy Hemi heads [Re: LAD 524] #2599107
12/31/18 09:39 AM
12/31/18 09:39 AM
wappinger falls new york
Jimi_Vignogna Offline
The newer Mopar aluminum head castings are also the “E” head. I run them on my Hemi stocker. Out of the box , honed the guides put a valve job in them and assembled. Never flowed them was pressed for time. Car ran 9.89@133.00 mph 3600# IMO great cylinder heads. Everything from a factory designed head fits.
Re: Need schooling on Eddy Hemi heads [Re: LAD 524] #2599533
12/31/18 11:06 PM
12/31/18 11:06 PM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Good info fellas thank for the heads up.
Jimi that's pretty good for an OOTB deal.
So other than getting some shaft stands, it seems like they will go on ok inc my TTI header fit.
Currently have Diamond pistons and wonder if going to a 2.30 intake will work with them along with the exhaust clearance.
Hmmm
Re: Need schooling on Eddy Hemi heads [Re: LAD 524] #2599692
01/01/19 10:29 AM
01/01/19 10:29 AM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
I also have these heads, with TTI headers and StageV rockers going into a 68 Hemi superstock clone, I plan on having to notch the block for intake valve clearance as I currently have a stock bore. I will be ordering my pistons from Diamond racing . Still collecting parts and Info as I go along.
Re: Need schooling on Eddy Hemi heads [Re: LAD 524] #2599763
01/01/19 12:48 PM
01/01/19 12:48 PM
Andrews,In. U.S.of A.
67_Satellite Offline
What's the story on the hump just upstream of the intake guide boss in the intake port?
Re: Need schooling on Eddy Hemi heads [Re: LAD 524] #2599837
01/01/19 02:11 PM
01/01/19 02:11 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
It’s just for added thickness under the edge of the spring pocket.
Re: Need schooling on Eddy Hemi heads [Re: 67_Satellite] #2599840
01/01/19 02:13 PM
01/01/19 02:13 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
It's a piece of tubing that is installed so they can make the port bigger.
Rich H.
Esse Quam Videri
Re: Need schooling on Eddy Hemi heads [Re: LAD 524] #2599843
01/01/19 02:18 PM
01/01/19 02:18 PM
So. Burlington, Vt.
So. Burlington, Vt.
I guess the correct answer depends on which hump is being referenced 🤦‍♂️
Re: Need schooling on Eddy Hemi heads [Re: LAD 524] #2599932
01/01/19 03:36 PM
01/01/19 03:36 PM
NE Ohio
NE Ohio
THE MOPAR Aluminum head P5153779 is made by edelbrock - but is not the same as the Victor Jr. head - the Mopar head is 2.25" intake and is a stock replacement head - the Victor Jr. was designed around the big bore motors (4.5) but can be used on the smaller bore motors with a big valve notch
Re: Need schooling on Eddy Hemi heads [Re: LAD 524] #2600337
01/02/19 10:15 AM
01/02/19 10:15 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Great info guys keep it coming....
I have a 4.530" bore so I dont think a notch is needed wink
Re: Need schooling on Eddy Hemi heads [Re: DoubleD] #2600443
01/02/19 02:42 PM
01/02/19 02:42 PM
So. Burlington, Vt.
So. Burlington, Vt.
Exactly.
The only “Edelbrock” branded G2 hemi head currently available is the the Victor.
The stock replacement heads made by Edelbrock are Mopar branded heads.
Re: Need schooling on Eddy Hemi heads [Re: LAD 524] #2600664
01/02/19 09:58 PM
01/02/19 09:58 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
My stageV heads only flow 367@.600 so those are awesome heads!
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Need schooling on Eddy Hemi heads [Re: LAD 524] #2600891
01/03/19 12:55 PM
01/03/19 12:55 PM
So. Burlington, Vt.
So. Burlington, Vt.
On my bench the Victors are right about 400 ootb on a 4.500 bore.
Re: Need schooling on Eddy Hemi heads [Re: LAD 524] #2601245
01/04/19 12:35 AM
01/04/19 12:35 AM
Superfreak
Superfreak
So what would be the price point for a set of the Victors after a cnc job?
Re: Need schooling on Eddy Hemi heads [Re: LAD 524] #2601445
01/04/19 01:38 PM
01/04/19 01:38 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I don't know of anybody CNCing Victors.
2011 Drag Pak Challenger
Re: Need schooling on Eddy Hemi heads [Re: LAD 524] #2601457
01/04/19 01:53 PM
01/04/19 01:53 PM
NE Ohio
NE Ohio
The only one I know of is Hughes Engines - you can look on their website - but for a set of assembled super prepped heads they list $3360 - they list the flow there also
flow tests below show results from our SAENZ 680 Flow Bench with a pipe.
Lift Intake
Stock Int Super Prepped Exhaust Stock Exh Super Prepped
.050 40.4 52.3 (+12) 35.7 35.3
.100 76.8 87.7 (+11) 70.0 72.9 (+3)
.150 111.5 128.2 (+17) 110.8 117.0 (+6)
.200 148.7 168.9 (+20) 151.2 151.0
.250 188.1 213.4 (+25) 179.2 181.0 (+1)
.300 226.7 258.5 (+32) 207.3 202.8 (-5)
.350 265.0 298.2 (+33) 229.5 223.8 (-6)
.400 303.9 338.2 (+35) 249.8 246.9 (-3)
.450 340.9 372.4 (+32) 266.4 269.7 (+3)
.500 372.6 399.0 (+27) 279.9 291.4 (+12)
.550 398.9 420.1 (+22) 286.6 307.5 (+21)
.600 413.8 433.0 (+20) 290.0 320.0 (+30)
.650 421.8 439.2 (+18) 290.5 328.8 (+38)
.700 429.9 442.8 (+13) 291.3 333.5 (+41)
.750 443.7
.800 446.4
Average 209.9 234.6
Re: Need schooling on Eddy Hemi heads [Re: LAD 524] #2601462
01/04/19 02:01 PM
01/04/19 02:01 PM
So. Burlington, Vt.
So. Burlington, Vt.
Hughes must have gotten the “really good” ones from Edelbrock.
The ones I’ve tested were more like 409@.800, on a 4.500 bore.
Exhaust was 240 without a tube and 273 with a 2-1/8” tube.
