Re: Need schooling on Eddy Hemi heads
[Re: LAD 524]
#2598805
12/30/18 02:39 PM
12/30/18 02:39 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
Larry Smith just posted this on FB direct Connected Mopar page.
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
[Re: LAD 524]
#2599837
01/01/19 02:11 PM
01/01/19 02:11 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
It’s just for added thickness under the edge of the spring pocket.
[Re: 67_Satellite]
#2599840
01/01/19 02:13 PM
01/01/19 02:13 PM
Posts: 17,841 S.E. Michigan
ZIPPY
S.E. Michigan
What's the story on the hump just upstream of the intake guide boss in the intake port? It's a piece of tubing that is installed so they can make the port bigger.
Rich H.
Esse Quam Videri
[Re: LAD 524]
#2599843
01/01/19 02:18 PM
01/01/19 02:18 PM
fast68plymouth
So. Burlington, Vt.
I guess the correct answer depends on which hump is being referenced 🤦♂️
[Re: DoubleD]
#2600443
01/02/19 02:42 PM
01/02/19 02:42 PM
fast68plymouth
So. Burlington, Vt.
THE MOPAR Aluminum head P5153779 is made by edelbrock - but is not the same as the Victor Jr. head - the Mopar head is 2.25" intake and is a stock replacement head - the Victor Jr. was designed around the big bore motors (4.5) but can be used on the smaller bore motors with a big valve notch Exactly. The only “Edelbrock” branded G2 hemi head currently available is the the Victor. The stock replacement heads made by Edelbrock are Mopar branded heads.
[Re: LAD 524]
#2600664
01/02/19 09:58 PM
01/02/19 09:58 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
My stageV heads only flow 367@.600 so those are awesome heads!
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: LAD 524]
#2600891
01/03/19 12:55 PM
01/03/19 12:55 PM
fast68plymouth
So. Burlington, Vt.
On my bench the Victors are right about 400 ootb on a 4.500 bore.
[Re: LAD 524]
#2601245
01/04/19 12:35 AM
01/04/19 12:35 AM
Superfreak
Superfreak
So what would be the price point for a set of the Victors after a cnc job?
[Re: LAD 524]
#2601462
01/04/19 02:01 PM
01/04/19 02:01 PM
fast68plymouth
So. Burlington, Vt.
Hughes must have gotten the “really good” ones from Edelbrock.
The ones I’ve tested were more like 409@.800, on a 4.500 bore. Exhaust was 240 without a tube and 273 with a 2-1/8” tube.
