What Distributor / Ignition Setup are you running ? #2600290
01/02/19 02:35 AM
01/02/19 02:35 AM
Tucson AZ,
MadMopars Offline OP
Tucson AZ,
Looking to buy an RB distributor and am curious what ignition setup you guys are running on your stuff. I've used the Mallory Unilites for years but was thinking about giving an MSD Pro Billet a shot mostly because I already have a new 6AL, Blaster 2 coil and MSD wires laying around. I know some of the MSD stuff has given people problems over the years but I think that probably applies to the Mallory's and every other brand if you look long enough. Anyhow, just looking for some info and feedback before I commit to anything. Thanks Guys!
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: What Distributor / Ignition Setup are you running ? [Re: MadMopars] #2600321
01/02/19 05:58 AM
01/02/19 05:58 AM
Stock Mopar magnetic pickup recurved with a big gold MSD race box, 404B,404C, 7,7C,7A,7ALA and now a MSD Grid with a non programmable digital 7 with the proper col for the MSD race boxes, not a big yellow Accel or any other coil designed for a points type ignition tsk
I've also used both of the MSD distributors with good results also thumbs
The Mopar brand of ECU kind of scare me so I step up for better thumbs
Re: What Distributor / Ignition Setup are you running ? [Re: MadMopars] #2600345
01/02/19 10:47 AM
01/02/19 10:47 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've used the stock stuff with good results. Currently running MSD crank trigger with a 440 source distributor. Though in this case the internal electronics aren't being used. The quality of the unit itself is nice. Near had an issue with the cap or rotor in 6 years.
Doug
Re: What Distributor / Ignition Setup are you running ? [Re: dvw] #2600351
01/02/19 11:14 AM
01/02/19 11:14 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Stock Chrysler magnetic pickup distributor that I rebuilt and recurved feeding an MSD 6AL. Reliable, cheap and works great.
'63 Dodge 330
11.19 @ 121 mph
Re: What Distributor / Ignition Setup are you running ? [Re: GY3] #2600363
01/02/19 11:50 AM
01/02/19 11:50 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Both my big block and small block have a MSD billet distributor and 7AL3 boxes.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: What Distributor / Ignition Setup are you running ? [Re: MadMopars] #2600364
01/02/19 11:58 AM
01/02/19 11:58 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
MSD Billet distributer, MSD 8.5mm wires, and MSD Digital-7 box.
69 GTX 68 Road Runner
Re: What Distributor / Ignition Setup are you running ? [Re: MadMopars] #2600411
01/02/19 01:39 PM
01/02/19 01:39 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
MSD billet - MSD crank trigger and recent change from a 7AL III to the MSD Grid
Re: What Distributor / Ignition Setup are you running ? [Re: MadMopars] #2600472
01/02/19 03:45 PM
01/02/19 03:45 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Mopar Performance distributors in two big blocks, MSD6al+msd coil in one, Frankenstein GM HEI/Ford TFI coil in the other.
The Frankenstein deal surprised me, I did not expect it to work as well as it does. I have an external soft touch rev limiter I can wire up, and might A/B test it with a 6 series msd someday.
Re: What Distributor / Ignition Setup are you running ? [Re: MadMopars] #2600513
01/02/19 04:51 PM
01/02/19 04:51 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
HI
stock recurved dist .crome box , done !
Re: What Distributor / Ignition Setup are you running ? [Re: MadMopars] #2600517
01/02/19 05:01 PM
01/02/19 05:01 PM
AndyF Offline
AndyF  Offline
No distributor or ignition box for me.
Re: What Distributor / Ignition Setup are you running ? [Re: MadMopars] #2600523
01/02/19 05:24 PM
01/02/19 05:24 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Crane HI-6 box w/ either a recurved MP OEM-type electronic w/ vac advance, or an oddball MP/Mallory billet mechanical-only piece I picked up years ago. Not sure there's any performance difference between the distributors, but the MP/Mallory is easier to adjust the advance curve... probably tighter tolerances in the shaft runout, too.
Re: What Distributor / Ignition Setup are you running ? [Re: MadMopars] #2600573
01/02/19 07:12 PM
01/02/19 07:12 PM
Maryland
twayne24365 Offline
twayne24365  Offline
Maryland
Running firecore billit distributors and msd6al boxes on a 383 and a 440, My truck is getting the same setup as well
Re: What Distributor / Ignition Setup are you running ? [Re: MadMopars] #2600638
01/02/19 09:18 PM
01/02/19 09:18 PM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
Engine is a low deck 452, probably Dan Costello's (RIP) last Mopar engine.
Recurved MP distributor with standard magnetic pickup, vacuum advance still hooked up running manifold vacuum. MSD 6AL box. Lucas sport coil. Works great.
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: What Distributor / Ignition Setup are you running ? [Re: MadMopars] #2600646
01/02/19 09:31 PM
01/02/19 09:31 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Rebuilt stock Mopar that was recurved...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: What Distributor / Ignition Setup are you running ? [Re: ZIPPY] #2600741
01/03/19 12:27 AM
01/03/19 12:27 AM
this. & dial in your curve. EDIT with a regular 70's electronic dist (not a newer Mallory based one). GM HEI 4 pin module
Re: What Distributor / Ignition Setup are you running ? [Re: MadMopars] #2600745
01/03/19 12:40 AM
01/03/19 12:40 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Last setup used a distributor from FBO that they curved & put their limiter plate in; spendy, but nice piece.
Otherwise it's been curved MP units except for the old tach-drive in the dragrace car.
All with vacuum advance except the race car.
Rest of the deal has been MSD6AL, F150 coil, usually Taylor wires, usually Champion plugs.
Re: What Distributor / Ignition Setup are you running ? [Re: RapidRobert] #2600746
01/03/19 12:40 AM
01/03/19 12:40 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Firecore tall distributor, MSD 6AL, MSD Blaster SS coil, Firecore wires, Denso Iridium plugs. Been running perfect for 4 years.
Gus beer
64 Plymouth Savoy
Dana 60
Re: What Distributor / Ignition Setup are you running ? [Re: MadMopars] #2600752
01/03/19 12:52 AM
01/03/19 12:52 AM
Tucson AZ,
Tucson AZ,
Doesn't seem to be alot of reason to spend the big bucks on the MSD distributor from the sounds of it. Now I just need convince myself to jump back to a basic electronic distributor instead of the Unilites that I've been running for years. I need to buy a distributor for this project anyhow so maybe it's time to try something new, or not...work I hate change. laugh2
Re: What Distributor / Ignition Setup are you running ? [Re: MadMopars] #2600789
01/03/19 02:49 AM
01/03/19 02:49 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
When you pull it apart to clean it, most likely the nylon bushing at the bottom of the housing will likely be crystallized and break when you drive out the roll pin. Fortunately there is a Hillman bushing sold as a pair for 99 cents at Lowes in the nut and bolt/hardware section.
Re: What Distributor / Ignition Setup are you running ? [Re: MadMopars] #2600791
01/03/19 03:01 AM
01/03/19 03:01 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run a Mallory race dist with no vacuum advance in my 63 because I got it for a great price. I still use the orange Mopar ECU I bought around 1999 because my sons car did use it and ran just as good with it as it does with MSD. I like it a lot as the mech advance is all adjustable real easy. On my sons Dart I run a factory B-block dist I just recurved with his MSD box. Honestly if I was buying a new dist today and money was no problem I would most likely just go with MSD. Ron
