Re: What Distributor / Ignition Setup are you running ?
[Re: MadMopars]
#2600321
01/02/19 05:58 AM
01/02/19 05:58 AM
Posts: 43,206 Bend,OR USA
Cab_Burge
Stock Mopar magnetic pickup recurved with a big gold MSD race box, 404B,404C, 7,7C,7A,7ALA and now a MSD Grid with a non programmable digital 7 with the proper col for the MSD race boxes, not a big yellow Accel or any other coil designed for a points type ignition I've also used both of the MSD distributors with good results also The Mopar brand of ECU kind of scare me so I step up for better
[Re: dvw]
#2600351
01/02/19 11:14 AM
01/02/19 11:14 AM
Posts: 4,681 Wichita
GY3
Wichita
Stock Chrysler magnetic pickup distributor that I rebuilt and recurved feeding an MSD 6AL. Reliable, cheap and works great.
[Re: GY3]
#2600363
01/02/19 11:50 AM
01/02/19 11:50 AM
Posts: 20,179 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Both my big block and small block have a MSD billet distributor and 7AL3 boxes.
[Re: MadMopars]
#2600364
01/02/19 11:58 AM
01/02/19 11:58 AM
Posts: 10,029 MN
JERICOGTX
MN
MSD Billet distributer, MSD 8.5mm wires, and MSD Digital-7 box.
69 GTX
68 Road Runner
[Re: MadMopars]
#2600646
01/02/19 09:31 PM
01/02/19 09:31 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Rebuilt stock Mopar that was recurved...
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: ZIPPY]
#2600741
01/03/19 12:27 AM
01/03/19 12:27 AM
RapidRobert
Frankenstein GM HEI/Ford TFI coil in the other. this. & dial in your curve. EDIT with a regular 70's electronic dist (not a newer Mallory based one). GM HEI 4 pin module
