What gear lube in Dana 60? #2597656
12/27/18 05:02 PM
12/27/18 05:02 PM
North Central, Indiana
Roughbird72 Offline OP
This has probably been asked a hundred times,but.
What gear lube would you guys suggest for a new street/strip Dana 60 w/spool? shruggy
72 Plymouth Roadrunner 11.08@123.25
Re: What gear lube in Dana 60? [Re: Roughbird72] #2597665
12/27/18 05:11 PM
12/27/18 05:11 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
We have always used 75W-140 full synthetic. Currently using Valvoline brand.
Re: What gear lube in Dana 60? [Re: Roughbird72] #2597678
12/27/18 05:57 PM
12/27/18 05:57 PM
AndyF Offline
AndyF  Offline
With a spool you could run anything. The clutch pack differentials are what require the special friction modifiers. Just go to Walmart and buy whatever gear oil is on sale.
Re: What gear lube in Dana 60? [Re: Roughbird72] #2597680
12/27/18 06:02 PM
12/27/18 06:02 PM
Kirkland, Washington
Pacnorthcuda Offline
Just make sure whatever you pick is GL-5 rated.
Re: What gear lube in Dana 60? [Re: Roughbird72] #2597685
12/27/18 06:29 PM
12/27/18 06:29 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
After putting stuff together, having someone beat on it for years, and being able to look at it again afterwards, I stick with what I've been using for years. Amsoil 75w-90 Severe Gear.
Re: What gear lube in Dana 60? [Re: Roughbird72] #2597698
12/27/18 07:18 PM
12/27/18 07:18 PM
Redline synthetic green up
Re: What gear lube in Dana 60? [Re: Roughbird72] #2597720
12/27/18 08:03 PM
12/27/18 08:03 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Re: What gear lube in Dana 60? [Re: Roughbird72] #2597725
12/27/18 08:08 PM
12/27/18 08:08 PM
Washington
madscientist Offline
Washington
Anything GL-6 rated.
Re: What gear lube in Dana 60? [Re: Dave Hall] #2597827
12/28/18 12:32 AM
12/28/18 12:32 AM
Originally Posted By Dave Hall
I use the Lightweight in my Dana 60 with a spool up
It had that in the rear end when I bought it when it had a blown B1 motor that pushed that car to 7.60 at 184+ MPH with a set of Pro 5.86 gears shock Those gears look excellent when I removed them so I stuck with that lube for the 4.56 Dana gears I put back in it up
Re: What gear lube in Dana 60? [Re: Cab_Burge] #2597840
12/28/18 01:08 AM
12/28/18 01:08 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Yikes eek Couldn't help but see that. Even with a big tire and tight converter, that's zingin' it.
Re: What gear lube in Dana 60? [Re: Roughbird72] #2597947
12/28/18 12:28 PM
12/28/18 12:28 PM
Thanks for the input guys thumbs
Re: What gear lube in Dana 60? [Re: Roughbird72] #2597984
12/28/18 02:34 PM
12/28/18 02:34 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I run the Redline Light Weight Shockproof too in the Charger that I race.
Running the regular Redline Gear oil in most everything else.
I did run the lightweight shockproof in a daily driver 2002 Ram 1500, and it seemed to be just fine with it. Not sure if there is much difference in running temperatures of the shockproof and normal synthetic oil?
Re: What gear lube in Dana 60? [Re: CMcAllister] #2598002
12/28/18 03:21 PM
12/28/18 03:21 PM
I'm thinking it was above 8000 RPM in the 1/4 mile shruggy
I was told that it had 5.38 in the rear when I bought the car and when my poor little 505 C.I. 400 block bracket motor had it tongue out at the 1000 Ft timers I found out why after pulling the cover to inspect the gears shock
It likes the 4:56 with both the 15x33x15 Goodyears and the smaller 14x32x15 M/T stiffwall up
Re: What gear lube in Dana 60? [Re: Roughbird72] #2598006
12/28/18 03:32 PM
12/28/18 03:32 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
All we EVER use is Torco.
Re: What gear lube in Dana 60? [Re: BobR] #2598056
12/28/18 05:11 PM
12/28/18 05:11 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Torco is a GL-6*, and is sold by Mark Williams. It is supposed to be really good for high shock applications. I know guys using Torco in really high abuse applications and swear by it.
*The GL-6 rating is inactive and has been for 25 years. But there are gear oils still marketed as meeting the spec, even though it can't be tested for it.
Re: What gear lube in Dana 60? [Re: Roughbird72] #2598084
12/28/18 06:38 PM
12/28/18 06:38 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Shock proof, or banana peels saw dust and molasses
Re: What gear lube in Dana 60? [Re: Roughbird72] #2598763
12/30/18 01:26 PM
12/30/18 01:26 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Due to someone's concern that gear lube has a limited shelf life, I inherited a ridiculous amount (about 20 cases) of Mobil 1 in 80w90 and 75w140.
So, for the foreseeable future, Zippy Performance uses Mobil 1 exclusively. Strictly for it's superior lubrication 😂
Shelf life: I figure if it can sit inside an axle for 20 years and still be good, especially with no miles...then it can sit on a shelf for a little longer than 4 years as well.
Rich H.
Esse Quam Videri
Re: What gear lube in Dana 60? [Re: Roughbird72] #2598771
12/30/18 01:38 PM
12/30/18 01:38 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Zippy, I think that is what is called a "lifetime supply"!
Re: What gear lube in Dana 60? [Re: Roughbird72] #2598781
12/30/18 01:51 PM
12/30/18 01:51 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Does anybody remember the mopar sperm oil rear end additive - man that stuff really had a smell to it
Re: What gear lube in Dana 60? [Re: DoubleD] #2598833
12/30/18 03:29 PM
12/30/18 03:29 PM
You can still buy it (Ford Brand) at your local Ford dealer, it is needed with any clutch type posi up
