Shocking discovery #2596430
12/24/18 07:31 PM
12/24/18 07:31 PM
Spring Valley ,Ca.
moparsquid Offline OP
Spring Valley ,Ca.
It had been at least 2 months since I drove my car so I wormed it up and did a lap around the block when I got back I noticed fluid under the left control arm thinking brake cylinder I looked at it and noticed fluid coming from the bottom of the shock its C E 3 way adj. that's about 22 years old ,my question is it bad or from lack of use?
Re: Shocking discovery [Re: moparsquid] #2596435
12/24/18 07:41 PM
12/24/18 07:41 PM
Kirkland, Washington
Pacnorthcuda Offline
Blew the seal, the shock is toast.
That will happen when a moparsquid worms up his car.
Re: Shocking discovery [Re: Pacnorthcuda] #2596443
12/24/18 07:59 PM
12/24/18 07:59 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
up beer yep fat fingered it again
Re: Shocking discovery [Re: moparsquid] #2596465
12/24/18 08:30 PM
12/24/18 08:30 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I just hate parts that fail so quickly. whistling
Re: Shocking discovery [Re: stumpy] #2596682
12/25/18 11:25 AM
12/25/18 11:25 AM
Milan Ohio
ct440rod Offline
ct440rod  Offline
Milan Ohio
Should still be under warranty.
Re: Shocking discovery [Re: moparsquid] #2596740
12/25/18 02:33 PM
12/25/18 02:33 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
What car? I have a good one off my Dart if you need one.
Re: Shocking discovery [Re: moparsquid] #2596835
12/25/18 05:48 PM
12/25/18 05:48 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
At 22 years old they are probably worn out anyway. whistling
Re: Shocking discovery [Re: justinp61] #2596854
12/25/18 06:26 PM
12/25/18 06:26 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
62 dodge dart thanks for the reply and offer
Re: Shocking discovery [Re: slantzilla] #2596856
12/25/18 06:28 PM
12/25/18 06:28 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
that is true but in actuality they have seen very little street time in that period like say 300 miles or less
Re: Shocking discovery [Re: moparsquid] #2596892
12/25/18 07:40 PM
12/25/18 07:40 PM
Khemi, Stygia
Mebsuta Offline
Mebsuta  Offline
Khemi, Stygia
Work on that.
68 Roadrunner. 383 4-spd. Beat up.
Re: Shocking discovery [Re: moparsquid] #2596901
12/25/18 08:02 PM
12/25/18 08:02 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Rubber expires with time not just with use
Re: Shocking discovery [Re: moparsquid] #2596949
12/25/18 10:51 PM
12/25/18 10:51 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Shaft can get corroded, even slightly. Or even dirt build up on exposed shaft.
Also the thin film of oil on shaft dries/runs off.
Then shaft moves and swipe seal is damaged.
Re: Shocking discovery [Re: moparsquid] #2597052
12/26/18 08:09 AM
12/26/18 08:09 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Seals hardened with age. The pros claim now to replace tires every 5 years regardless of tread depth due to aging/deterioration of rubber. Don't kill me that's what the pros are saying.
Keep old mopars alive.
Re: Shocking discovery [Re: 2boltmain] #2597451
12/27/18 04:35 AM
12/27/18 04:35 AM
I was told 20 yrs ago by a trusted Cooper tire dealer to replace all radials after two to three years no matter how much mileage was on them shruggy
Re: Shocking discovery [Re: moparsquid] #2597974
12/28/18 01:56 PM
12/28/18 01:56 PM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
Good way to sell tires. Had a set of BFG's on a car for 25 years. All depends how they are stored.
Re: Shocking discovery [Re: Cab_Burge] #2598112
12/28/18 07:53 PM
12/28/18 07:53 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
And you believe that guy? laugh2 If radial tires (or any other for that matter) have to be replaced after only two years, then something is seriously wrong with the rubber industry!
Plymouth Makes It!
Re: Shocking discovery [Re: Cab_Burge] #2598120
12/28/18 08:19 PM
12/28/18 08:19 PM
manitoba canada
BleedDodge Offline
BleedDodge  Offline
manitoba canada
Wow. I have some cooper ht plus tires on my old truck that I bought summer of 2008 and they look next to new. Can you imagine if I’d replaced them four times already by that math how much money I would have wasted ?
