Shocking discovery
#2596430
12/24/18 07:31 PM
12/24/18 07:31 PM
Posts: 1,107 Spring Valley ,Ca.
moparsquid
Spring Valley ,Ca.
It had been at least 2 months since I drove my car so I wormed it up and did a lap around the block when I got back I noticed fluid under the left control arm thinking brake cylinder I looked at it and noticed fluid coming from the bottom of the shock its C E 3 way adj. that's about 22 years old ,my question is it bad or from lack of use?
Re: Shocking discovery
[Re: moparsquid]
#2596892
12/25/18 07:40 PM
12/25/18 07:40 PM
Posts: 259 Khemi, Stygia
Mebsuta
Khemi, Stygia
that is true but in actuality they have seen very little street time in that period like say 300 miles or less Work on that.
68 Roadrunner. 383 4-spd. Beat up.
[Re: moparsquid]
#2597052
12/26/18 08:09 AM
12/26/18 08:09 AM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Seals hardened with age. The pros claim now to replace tires every 5 years regardless of tread depth due to aging/deterioration of rubber. Don't kill me that's what the pros are saying.
Keep old mopars alive.
[Re: Cab_Burge]
#2598112
12/28/18 07:53 PM
12/28/18 07:53 PM
Posts: 5,324 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
I was told 20 yrs ago by a trusted Cooper tire dealer to replace all radials after two to three years no matter how much mileage was on them And you believe that guy? If radial tires (or any other for that matter) have to be replaced after only two years, then something is seriously wrong with the rubber industry!
Plymouth Makes It!
