Small Block Oil Pan #2597325
12/26/18 10:36 PM
12/26/18 10:36 PM
Carson City, Nevada
Biginchmopar Offline OP
Carson City, Nevada
Has anybody used a Milodon Oil Pan with a 4.250" stroke crankshaft?
The crankshaft will have 2.00" rod journals so that should help.
Thanks!
Re: Small Block Oil Pan [Re: Biginchmopar] #2597350
12/26/18 11:35 PM
12/26/18 11:35 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Almost ZERO info in your post on what pan you are looking at but this one is listed for up to a 4.125 stroke.
Brand:Milodon
Manufacturer's Part Number:30941
Part Type:Oil Pans
Product Line:Milodon Street and Strip Oil Pans
Summit Racing Part Number:MIL-30941
UPC:806621309412
Sump Style: Wet
Stroker Clearanced: Yes
Maximum Stroke with OE Rod: 4.125 in.
Dipstick Provision: No
Dipstick Included: No
Sump Location: Center
Oil Pan Capacity: 7.00 quarts
Oil Pan Depth (in): 7.750 in.
Oil Pan Material: Steel
Oil Pan Finish: Gold iridited
Baffled: Yes
Kicked Out: Yes
Kickout Position: Driver and passenger side
Windage Tray Included: No
Pickup Included: No
Oil Pump Included: No
Oil Pump Driveshaft Included: No
Crank Scraper Included: No
Drain Plug Thread Size: 1/2-20 in.
Gaskets Included: No
Hardware Included: No
Quantity: Sold individually.
Notes: Low-profile triangulated sump. 1" shallower than 30940 with improved oil control. Will allow use of a windage tray. Oil pan front depth is 3.750 in.
In-Store Pickup:Choose In-store pick-up (OH, NV, GA, TX) on our web site.
Milodon street and strip oil pans are designed for performance street as well as drag strip applications. They will fit most stock chassis and steering, as well as most headers. These well-engineered oil pans feature internal baffling that can free up additional horsepower. They're available in deep-sump and low-profile designs and are a necessity where high-volume oil pumps and increased rpm ranges are used.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Small Block Oil Pan [Re: Biginchmopar] #2597439
12/27/18 03:45 AM
12/27/18 03:45 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
How about Kevco?
Re: Small Block Oil Pan [Re: pittsburghracer] #2599236
12/31/18 02:56 PM
12/31/18 02:56 PM
Carson City, Nevada
Carson City, Nevada
Brand:Milodon
Part Type:Oil Pans
UPC:806621309412
Sump Style: Wet
Baffled: Yes
Kicked Out: Yes
Pickup Included: No
Thanks Pitts for the heads up on not enough info.
So back to it
I would like to run a Milodon 30935 (The Ritter Block I have takes a 340 pan)
Since I'm going to run a 2.00" rod journal and steel rod I don't believe I'll have any trouble going to the 4.250' stroke.
Somebody please correct me if I'm wrong but I believe If I add .125" stroke and take .125" off the rod journal I should have the same total diameter in swing radius as 4.125" Stroke with a 2.125" rod journal right?
Re: Small Block Oil Pan [Re: Biginchmopar] #2601587
01/04/19 05:04 PM
01/04/19 05:04 PM
Kansas, Topeka
69 lawndart Offline
69 lawndart  Offline
Kansas, Topeka
Yes I have the standard deep Milodon pan with a 4.25" stroke and Compstar rods. The biggest problem I had is the pickup tube clearing the rods.
Re: Small Block Oil Pan [Re: 69 lawndart] #2601597
01/04/19 05:33 PM
01/04/19 05:33 PM
Carson City, Nevada
Carson City, Nevada
Thanks for the info. beer
