need to dye seat belts #2596906
12/25/18 08:19 PM
12/25/18 08:19 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
what are we using to dye seat belts now? thanks
Re: need to dye seat belts [Re: moparpro] #2596913
12/25/18 08:50 PM
12/25/18 08:50 PM
Kirkland, Washington
Pacnorthcuda Offline
I would still use Rit dye and salt if I was doing a set again.
Re: need to dye seat belts [Re: Pacnorthcuda] #2596928
12/25/18 09:43 PM
12/25/18 09:43 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I use Rit dye all the time but I always forget how much salt should be added??
Ron
Re: need to dye seat belts [Re: RJS] #2596961
12/25/18 11:25 PM
12/25/18 11:25 PM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
I used Rit also. Washed them first by hand with a scrub brush and Dawn, and then by putting them in pillow cases to keep from having them beat up the inside of the washing machine. Boiled them in a pan like directions on the package said with whatever salt the instructions said to use. I changed my belts from green to black and the color change worked out perfect, other than having the sewn on labels turn black along with some of the soft rubber turning from clear to black. Belts came out even colored and flexible.
Re: need to dye seat belts [Re: John Brown] #2596966
12/25/18 11:55 PM
12/25/18 11:55 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
do i remove belt buckles before boiling?
Re: need to dye seat belts [Re: moparpro] #2596995
12/26/18 01:32 AM
12/26/18 01:32 AM
South Bend
South Bend
I removed the plastic covers.....
Re: need to dye seat belts [Re: moparpro] #2597028
12/26/18 03:52 AM
12/26/18 03:52 AM
No, you can't. They are stitched on in a specific safety related manner------in fact, the whole aspect of boiling / dying them voids original safety (so they say) but what are ya gonna do?
Re: need to dye seat belts [Re: moparpro] #2597110
12/26/18 01:17 PM
12/26/18 01:17 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Buckles can be removed if disasembled but having done that to ONE I can tell you you'll probably cause more damage than if you leave them on.
Now if someone can explain how to refinish '68/69 buckles that would be awesome !!!
