A-body console carpet pics #2593135
12/17/18 01:55 PM
12/17/18 01:55 PM
Clinton, NJ
N
njmopar Offline OP
njmopar  Offline OP
N
Clinton, NJ
Hello -
Does anyone have a photo of the carpet surround around the console mounted on the car? This is for a 68 Dart.
I have the carpet piece premade/cut, but to me it looks tall. Would drape down the hump pretty far. I did not have on my car to compare.
Also, grommet or no grommet for the hi-beam switch? I am seeing no traces of any grommet ring on my old carpet, so I am assuming no.
Thanks.
Re: A-body console carpet pics [Re: njmopar] #2593532
12/18/18 12:59 AM
12/18/18 12:59 AM
Kingston, IL USA!
gts340swinger Offline
Kingston, IL USA!
You should have the grommet on your high beam switch. It is just a piece of plastic that the carpet slips inside the edge so it probably wouldn't leave much of a mark.
As for the carpet panels, I will see is I can get some pictures. From memory, the panels do hang down past the console to seal up the gap.
Mr. Norm's "Fanatic" (idiot)
71 Mr. Norm's Demon GSS
77 Mr. Norm's personal B250 GSS van
76 Mr. Norm's KZ900 Motor Sports Special
69 Mr. Norm's M code Dart GTS
69 D100
68 Barracuda
64 Valiant V200
07 Charger Daytona SST 6 speed test mule.
Re: A-body console carpet pics [Re: njmopar] #2593752
12/18/18 02:24 PM
12/18/18 02:24 PM
New York
rarefish Offline
rarefish  Offline
New York
I'm on the other side of the high beam switch grommet debate and I say no grommets were installed from the factory.
Re: A-body console carpet pics [Re: rarefish] #2593888
12/18/18 06:17 PM
12/18/18 06:17 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
No grommets installed from the factory. I have pictures of the carpet around consoles but not here at work, I will post some when I get home. wave
JB Rhinehart, Realist
A-Body's RULE!
Re: A-body console carpet pics [Re: njmopar] #2594470
12/19/18 10:55 PM
12/19/18 10:55 PM
Clinton, NJ
N
njmopar Offline OP
njmopar  Offline OP
N
Clinton, NJ
Just a reminder Rhino smile
Hoping to make a weekend project.
Re: A-body console carpet pics [Re: njmopar] #2594585
12/20/18 05:03 AM
12/20/18 05:03 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
This is factory console carpet from a '69 Barracuda M4. The driver side hangs down farther than the passenger side.
21-17 Console.carpet1.L front.jpg21-17 Console.carpet2.L middle.jpg21-17 Console.carpet3.L rear.jpg21-17 Console.carpet4.rear view.Carpet much longer on L side..jpg
Re: A-body console carpet pics [Re: njmopar] #2594586
12/20/18 05:11 AM
12/20/18 05:11 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Next two show backside of driver side. What looks like a tear behind the hand is apparently the way the factory made it.
Last one is entire console carpet laid flat. Driver side is away from the camera; passenger side is closest.
21-17 Console.carpet16.L rear.what looks like torn edge left center is apparently original.jpg21-17 Console.carpet17.L rear long folded edge.jpg21-17 Console.carpet28.front of R side in foreground.jpg
Re: A-body console carpet pics [Re: kentj340] #2594615
12/20/18 10:36 AM
12/20/18 10:36 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
That looks exactly like the pictures I was going to post last night, oops... realcrazy
A-Body's RULE!
Re: A-body console carpet pics [Re: njmopar] #2594617
12/20/18 10:42 AM
12/20/18 10:42 AM
Clinton, NJ
N
njmopar Offline OP
njmopar  Offline OP
N
Clinton, NJ
Very cool. From those I can get good dimensions. Interesting how it tapers lower to the back.
I wonder if the auto carpet has the same slot/cut behind where the smaller bump would be? The repro piece I have does not have the slot. I think it is more of a universal one for auto or manual.
Thanks!
Re: A-body console carpet pics [Re: njmopar] #2594744
12/20/18 05:26 PM
12/20/18 05:26 PM
Illinois, USA
superbee69 Offline
superbee69  Offline
Illinois, USA
Where can you get the molded hump for the carpet to glue to on the left hand side?
Re: A-body console carpet pics [Re: superbee69] #2594865
12/21/18 12:01 AM
12/21/18 12:01 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
You can't get the molded cardboard piece. Someone used to make a fiberglass replica and sold them on eBay, but that was years ago and I haven't seen them for years. shruggy
A-Body's RULE!
Re: A-body console carpet pics [Re: njmopar] #2594885
12/21/18 12:36 AM
12/21/18 12:36 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Photos of the molded hump. The front half is laminated paper, about 10-12 layers or more, maybe with varnish on it? The rear is just glue on the back of stretched/shaped carpet.
21-17 Console.carpet12.L middle fiberboard fastener.jpg21-17 Console.carpet13.L middle folded edge.jpg21-17 Console.carpet14.L middle fastener 2.jpg21-17 Console.carpet15.middle fastener 3.jpg
Re: A-body console carpet pics [Re: njmopar] #2594894
12/21/18 12:47 AM
12/21/18 12:47 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
More.
21-17 Console.carpet36.L middle shaped area.jpg21-17 Console.carpet37.closeup of glue for stiffening.jpg21-17 Console.carpet38.closeup of paper layers in fiberboard.jpg
Re: A-body console carpet pics [Re: kentj340] #2595006
12/21/18 12:33 PM
12/21/18 12:33 PM
Illinois, USA
superbee69 Offline
superbee69  Offline
Illinois, USA
Need 2 of them someone needs to reproduce them again.why would they stop?ug!
Re: A-body console carpet pics [Re: kentj340] #2595057
12/21/18 01:56 PM
12/21/18 01:56 PM
New York
rarefish Offline
rarefish  Offline
New York
Is that the original color of your console or has it been resprayed?
I can't tell it its blue or green in color...
Re: A-body console carpet pics [Re: njmopar] #2595381
12/22/18 04:42 AM
12/22/18 04:42 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
That's the factory original paint, Bayou Green Metallic Low Gloss, according to the FSM.
Car is ready soon to go to paint shop, and the console is just about the only thing that doesn't need repaint.
I might make molded humps for sale later, but not now - I'm building my climate controlled Mopar man cave.
Re: A-body console carpet pics [Re: kentj340] #2595414
12/22/18 10:39 AM
12/22/18 10:39 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Gratuitous shot of three 4-speed consoles and another pic of the carboard laminated cover thingy... penguin
A-Body's RULE!
Re: A-body console carpet pics [Re: njmopar] #2595431
12/22/18 11:50 AM
12/22/18 11:50 AM
Clinton, NJ
N
njmopar Offline OP
njmopar  Offline OP
N
Clinton, NJ
Almost looks like beef jerky is the last photo. Lol.
Re: A-body console carpet pics [Re: njmopar] #2595463
12/22/18 01:28 PM
12/22/18 01:28 PM
moparx Offline
moparx  Offline
NAAA, it's BACON ! biggrin drool
beer
Re: A-body console carpet pics [Re: njmopar] #2595746
12/23/18 12:43 PM
12/23/18 12:43 PM
New York
rarefish Offline
rarefish  Offline
New York
Black carpet vs Colored carpet debate when the car has a 4 speed and a colored "non-black interior"
4 speed without the console option, the rule seems to be black carpets on all interiors, but...
When a 4 speed is ordered with the console option and the interior is not black then the console color will match the interior color?
Does this sound right?
