Fuel filter mounting brackets #2594387
12/19/18 07:35 PM
12/19/18 07:35 PM
Martinsville, IN
cdwmotorsports Offline OP
Martinsville, IN
I have the following fuel filters and need mounting ideas for them, one is 1.25” diameter and one is 1.75” diameter.
https://www.summitracing.com/parts/rus-650103
https://www.summitracing.com/parts/sum-230117-b
eBay-cdwmotorsports
Re: Fuel filter mounting brackets [Re: cdwmotorsports] #2594399
12/19/18 07:51 PM
12/19/18 07:51 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Small and light enough to just be plumbed in line and let the hose support it. Or use an adapter and attach it to the pump or tank inlets/outlets.
Re: Fuel filter mounting brackets [Re: cdwmotorsports] #2594401
12/19/18 07:52 PM
12/19/18 07:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I made my own mounts.. .020 stainless with a
rap of rubber on the inside.. very simple and
has been on there 20 years now
EDIT
Correction.. it was .020 stainless
wave
Re: Fuel filter mounting brackets [Re: cdwmotorsports] #2594409
12/19/18 08:04 PM
12/19/18 08:04 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I have used dune buggy rollbar mounts for stuff like that. I avoid the chrome plated stuff.
www.pacificcustoms.com/billet-clamp-on-mounts.html
"Just a Bracket car dressed up like a streetcar"
Re: Fuel filter mounting brackets [Re: cdwmotorsports] #2594420
12/19/18 08:34 PM
12/19/18 08:34 PM
AndyF Offline
AndyF  Offline
I don't want to go all Captain Obvious on you but if you search for fuel filter mounting brackets on Summit you'll find a bunch: https://www.summitracing.com/search/part-type/fuel-filter-mounting-brackets?ibanner=SREPD4
Re: Fuel filter mounting brackets [Re: cdwmotorsports] #2594498
12/19/18 11:52 PM
12/19/18 11:52 PM
tucson az
frank Offline
frank  Offline
tucson az
The hose will support those filters if needed. I mounted my filter under the car on the right hand frame rail just forward of the passenger door leading edge. . I purchased some pre-bent brackets from the Home Depot (they have many shapes and sizes), bent them a tad to securely cradle my filter, and welded it to the frame rail. It would also be very easy to attach a hose clamp to the bracket that would secure the filter in place.
Re: Fuel filter mounting brackets [Re: CMcAllister] #2594522
12/20/18 01:10 AM
12/20/18 01:10 AM
Don't use either one of those between the fuel tank and electric fuel pump tsk I learn that lesson the hard way thumbs
What electric fuel pump are you using and what size fuel filter micron rating size do they recommend to use between the tank and pump?
Re: Fuel filter mounting brackets [Re: AndyF] #2594575
12/20/18 04:00 AM
12/20/18 04:00 AM
Martinsville, IN
Martinsville, IN
I have done that didn’t see the sizes I need which is why I came here and asked.
eBay-cdwmotorsports
Re: Fuel filter mounting brackets [Re: Cab_Burge] #2594577
12/20/18 04:02 AM
12/20/18 04:02 AM
Martinsville, IN
Martinsville, IN
Why shouldn’t I use them between the fuel cell and fuel pump? All I see anymore is how there needs to be a filter pre and post pump.
I am currently using a Holley blue pump. I have never seen anything stating a micron rating for it.
eBay-cdwmotorsports
Re: Fuel filter mounting brackets [Re: frank] #2594578
12/20/18 04:03 AM
12/20/18 04:03 AM
Martinsville, IN
Martinsville, IN
This is how they are currently, I just don’t like it. Both are in the trunk near the fuel cell and pump.
eBay-cdwmotorsports
Re: Fuel filter mounting brackets [Re: Just-a-dart] #2594579
12/20/18 04:08 AM
12/20/18 04:08 AM
Martinsville, IN
Martinsville, IN
Thanks, that is exactly what I was hoping to find.
eBay-cdwmotorsports
Re: Fuel filter mounting brackets [Re: cdwmotorsports] #2594654
12/20/18 01:06 PM
12/20/18 01:06 PM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
I agree, those are for the pressure side between pump and carb. I use a spin on with #12 pre-pump. You can even get them with water separating capacity with a petcock drain.
Re: Fuel filter mounting brackets [Re: cdwmotorsports] #2594701
12/20/18 03:34 PM
12/20/18 03:34 PM
I am currently using a Holley blue pump. I have never seen anything stating a micron rating for it. [/quote]
I was told by Magnafuel to use a 100 micron or bigger filter between the tank and there pumps, I used a BG 500 filter that had a paper element in it(10 micron rating down realcrazy) and could not richen the mixture up enough to slow the car down, the wide ban showed it going lean from the starting line and got leaner as it accelerated, that was with their 275 pump shruggy
I bought a bigger 300 pump and had the exact same results on the wide ban so I change the filter to a bigger 80 micron rating and it went rich work
On your deal you may be fine with those filters with the small Holley blue pump, it depends on how much power your going to make work
Re: Fuel filter mounting brackets [Re: cdwmotorsports] #2594720
12/20/18 04:12 PM
12/20/18 04:12 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
I made my own.
Aluminum strap drilled over sized and put a rubber grommet in the hole.
Mount anywhere you want.
Re: Fuel filter mounting brackets [Re: cdwmotorsports] #2594766
12/20/18 06:45 PM
12/20/18 06:45 PM
PA
Harry's Taxi 2 Offline
PA
The Summit 100 micron between the tank and pump will work just fine. I have that exact one before my Aerospace Components 400gph pump. Fuel pressure and volume don't fluctuate one bit.
I don't have one after the pump and have not seen a need for one.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Fuel filter mounting brackets [Re: cdwmotorsports] #2594770
12/20/18 06:58 PM
12/20/18 06:58 PM
New York
polyspheric Offline
polyspheric  Offline
New York
This^^^
Rule #1 of hydraulic engineering: no restrictions on the suction (LP) side.
Boffin Emeritus
Re: Fuel filter mounting brackets [Re: Harry's Taxi 2] #2594933
12/21/18 03:11 AM
12/21/18 03:11 AM
Martinsville, IN
Martinsville, IN
Thanks, that is what I had read and been told was big micron filter before the pump and the smaller filter after the pump. If I run into issues i'll drop back and punt but for now I am sticking with what I have. I'm not out there looking to knock any ET or speed barriers down or build huge power. I never even ran a filter pre-pump with the old pump and the same cell, I ran a Fram paper filter one but I figured technology had changed in the 20 years since I had built the original plan at 25.
eBay-cdwmotorsports
Re: Fuel filter mounting brackets [Re: cdwmotorsports] #2594939
12/21/18 04:32 AM
12/21/18 04:32 AM
I thought I saw a 10 micron(not the 100 micron) and 40 micron on the links to the Summit adds, sorry for not seeing it was a 100 micron on the first view blush
Use the 100 micron between the tank and pump and a 10 micron between the pump and the carb up
Re: Fuel filter mounting brackets [Re: polyspheric] #2594960
12/21/18 08:59 AM
12/21/18 08:59 AM
PA
PA
This^^^
I've learned over and over through the years, that when "experts" implement "rules", they should be questioned and quite often, disregarded as new factors come into play from when the original "rule" was stated.
in this case, is a 100 micron pre-filter actually a significant, measurable restriction? in my non-expert verified experience, no it is not.
Re: Fuel filter mounting brackets [Re: cdwmotorsports] #2595094
12/21/18 03:33 PM
12/21/18 03:33 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I like a filter to protect that expensive pump. Using one with a less restrictive micron rating AND paying attention to the old advice of using 1 or 2 dash size larger plumbing between the pump and the tank should reduce any restriction issues.
Along with that, keep your jugs, funnels, etc. clean so you don't pour trash into the tank along with the fuel. I used a paint strainer in the fuel funnel. Surprising what it would catch sometimes.
