1970,1971 'Cuda convertible question #2590199
12/11/18 01:59 AM
12/11/18 01:59 AM
Mattituck NY.
FJ6AAR Online content OP
FJ6AAR  Online Content OP
Mattituck NY.
Hi, is there anybody out there that owns a 1970 or 1971 'Cuda/Barracuda convertible that can give me a measurement? The measurement needed is the width of the rear Deck Filler panel. As you know, the convertible uses a smaller width piece than a hardtop. I need to modify a hardtop piece and the original piece is no longer available to take measurements from. The places I need measured are in the photo below. Basically, I need the measurements of the three black lines. To be clear, it is only the visual part when the trunk is closed and the center molding is attached. I understand that the two end measurements should be the same. Any help will be greatly appreciated. Thanks.
https://ibb.co/12d2dz5
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
Re: 1970,1971 'Cuda convertible question [Re: FJ6AAR] #2590337
12/11/18 01:21 PM
12/11/18 01:21 PM
3
340clone Offline
340clone  Offline
Will a Challenger work, or does Cuda have a unique panel?
Re: 1970,1971 'Cuda convertible question [Re: 340clone] #2590540
12/11/18 07:58 PM
12/11/18 07:58 PM
Mattituck NY.
Mattituck NY.
Hi, that is a good question. I know a lot of the inner unseen unique convertible pieces are not the same between the two. I'm going to guess it probably isn't. Maybe somebody can chime in who knows for sure?
Re: 1970,1971 'Cuda convertible question [Re: FJ6AAR] #2590608
12/11/18 10:47 PM
12/11/18 10:47 PM
Columbus, Ohio
Chally426 Offline
Chally426  Offline
Columbus, Ohio
5 1/2" in the center, hooking the tape over the edge where the trim goes to where it starts to turndown for the trunk
Re: 1970,1971 'Cuda convertible question [Re: FJ6AAR] #2590628
12/11/18 11:31 PM
12/11/18 11:31 PM
Mattituck NY.
Mattituck NY.
Chally426 - thank you..! And thank you 340clone too. Chally426, that is for a 'Cuda/Barracuda, correct? Thank you , Rob
Re: 1970,1971 'Cuda convertible question [Re: FJ6AAR] #2591078
12/12/18 10:34 PM
12/12/18 10:34 PM
Columbus, Ohio
Chally426 Offline
Chally426  Offline
Columbus, Ohio
Yes... Cuda/barracuda
Re: 1970,1971 'Cuda convertible question [Re: FJ6AAR] #2591103
12/12/18 11:19 PM
12/12/18 11:19 PM
Mattituck NY.
Mattituck NY.
Thank You....!
Re: 1970,1971 'Cuda convertible question [Re: FJ6AAR] #2591244
12/13/18 12:12 PM
12/13/18 12:12 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
IIRC, member "convertcuda" Ken, sells/makes new repro dutchman panels for both E bodies
Re: 1970,1971 'Cuda convertible question [Re: FJ6AAR] #2591264
12/13/18 12:50 PM
12/13/18 12:50 PM
Mattituck NY.
Mattituck NY.
Thanks Dayclona, I'm aware of Ken. I had a local fabrication shop convert my quarters and they did a fantastic job. They will be making this piece for me as well.
Re: 1970,1971 'Cuda convertible question [Re: FJ6AAR] #2591933
12/14/18 05:04 PM
12/14/18 05:04 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Any step by step pictures of the conversion process you can share?
Re: 1970,1971 'Cuda convertible question [Re: FJ6AAR] #2592322
12/15/18 02:17 PM
12/15/18 02:17 PM
Massachussetts
RCKTMN Offline
RCKTMN  Offline
Massachussetts
Hello FJ6AAR,
Couldn't figure out how to post them, so I sent you an email with some pics off my 1970 Barracuda convertible.
Regards,
Paul
1970 Barracuda Convertible
1970 Newport Convertible
1970 Satellite Convertible
1974 'Cuda shell - '71 conversion
1988 Oldsmobile Cutlass w/455
2003 RAM3500 CTD
2007 Caliber R/T AWD
2007 Magnum SRT-8
2016 Chrysler Town & Country
Re: 1970,1971 'Cuda convertible question [Re: FJ6AAR] #2592395
12/15/18 03:49 PM
12/15/18 03:49 PM
Mattituck NY.
Mattituck NY.
Hi Paul, I replied to your email - Thank You, Rob
Re: 1970,1971 'Cuda convertible question [Re: larry4406] #2592401
12/15/18 04:01 PM
12/15/18 04:01 PM
Mattituck NY.
Mattituck NY.
Larry, you have a PM. Rob
