Fuel injection question #2591756
12/14/18 12:33 PM
12/14/18 12:33 PM
Palm Coast, FL (near Daytona B...
Blown_Hemi Offline OP
I am thinking of putting fuel injection on my 440. What is the best kit? The engine is a 440 .030 over. 9.75:1 compression. Iron open chamber heads ported using the old MP templates. MP 484 purple stick with 1.6:1 roller rockers. Performer RPM intake. Holley 800 DP carb. Timing is 38 total, 21 initial and 17 mechanical.
I had an old Holley ProJection on it and it ran terrible, it could not learn the low vacuum at idle. Looking for something that can learn my engine combo.
Fuel pump is a Mallory 140 pump with a return regulator.
Thanks Chris.
Ask me my opinion of Frank Mitchell....... A Mopar crook!
Re: Fuel injection question [Re: Blown_Hemi] #2591774
12/14/18 12:52 PM
12/14/18 12:52 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
what's your budget? best is really subjective, are you looking for self learning? most functionality? easy to bolt on? cheapest?
fitech is really popular its tbi, sniper maybe a little better software wise, but both will depend on how good the install is.
port injection is better than TBI but way more expensive to implement and has a lot of other options and tuning scenarios you can get into, coil near plug, sequential vs batch fire etc.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Fuel injection question [Re: Jerry] #2591907
12/14/18 04:04 PM
12/14/18 04:04 PM
I want tbi. Self learning would be nice. Budget not really sure of $1000 to $2000.
Re: Fuel injection question [Re: Blown_Hemi] #2591911
12/14/18 04:09 PM
12/14/18 04:09 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Holley Sniper, with the cost being about the same now as the FiTech systems it is an easy choice. Better quality and Tech support.
The only Carbs I care about are under the hood!
Re: Fuel injection question [Re: Blown_Hemi] #2591922
12/14/18 04:39 PM
12/14/18 04:39 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not sure $2k will cover it. The EFI kit will be about $1000, then you need to address the fuel delivery setup.
Don't be the exception.
Re: Fuel injection question [Re: Blown_Hemi] #2591967
12/14/18 06:04 PM
12/14/18 06:04 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Thanks Chris.
Go with the Holley Sniper, either by itself for $1K or buy the one that includes the fuel system for $1260, but you better buy it before the Holley Days promotion ends at the end of December.
The Sniper handles low vacuum engines very well because you can connect with a laptop and tune the low RPM area yourself. Most "self-learning" systems can't do that.
Re: Fuel injection question [Re: Mopar_Rich] #2591995
12/14/18 07:25 PM
12/14/18 07:25 PM
Thanks Chris.
I was just looking at that at work. Price I saw was $1280 with the fuel system.
Re: Fuel injection question [Re: Blown_Hemi] #2592011
12/14/18 07:49 PM
12/14/18 07:49 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
that fuel system is not complete. You will need a way to feed that pump as steady source of solid fuel. EFI systems die if you try to pump air and the stock tank isn't baffled.
Re: Fuel injection question [Re: Supercuda] #2592017
12/14/18 08:04 PM
12/14/18 08:04 PM
I forgot to say I have a 45 gallon fuel tank with a 3/8" pickup at the bottom of the tank and it is baffled.
This engine is in my 1978 Ramcharger.
Re: Fuel injection question [Re: Blown_Hemi] #2592023
12/14/18 08:07 PM
12/14/18 08:07 PM
Watching Garage Squad and they are installing a MSD Atomic fuel injection. Anybody have thoughts on these units?
Re: Fuel injection question [Re: Blown_Hemi] #2592036
12/14/18 08:26 PM
12/14/18 08:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
When I put TBI on my 87 Diplomat any time I got below half a tank it would suck air on hard turns or stops, killing the engine. Anywhere close to a quarter tanks and it was virtually undriveable.
I ended up going with a surge tank fed by the original mechanical fuel pump with the TBI return also plumbed into the surge tank with an over flow going back to the vehicle tank. This was back before all the fancy stuff they have today. That Holley Hydramat looks real interesting, even if it's pricey.
Re: Fuel injection question [Re: Supercuda] #2592082
12/14/18 10:04 PM
12/14/18 10:04 PM
I guess I just need to decide on what kit, leaning towards the Sniper. Then upgrade my in cab isolated fuel pressure gauge to 100 psi and my under hood gauge to 100 psi. I already have 3/8" ss supply and return lines.
Re: Fuel injection question [Re: Blown_Hemi] #2592144
12/15/18 12:28 AM
12/15/18 12:28 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Your old Holley wasn't the Commander 950 Pro was it? It can actually be beaten into submission to deal with cams with choppy idle from overlap.
I had one on my 493 with an MP509 that ran ok once we tweaked the under 1800 rpm part of the map to alpha/numeric.
Kevin
Re: Fuel injection question [Re: Blown_Hemi] #2592157
12/15/18 12:58 AM
12/15/18 12:58 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Put the Atomic on a stroked 360 (408) runs great. It’s very tuneable with the hand held. Bought it before the Holly Sniper came out. If I was doing it today I would go with the sniper.
Re: Fuel injection question [Re: Blown_Hemi] #2592176
12/15/18 02:16 AM
12/15/18 02:16 AM
tucson az
frank Offline
frank  Offline
tucson az
I went with the Super Sniper system for my 511 build. I already had a good fuel delivery system and I liked the idea of better drivability vs overall performance. All in I'm under 2K and that includes the matching distributer, ECU and coil. My engine is 400/511, Trick Flow heads, 10:1, 246, 248 hyd roller, and either Holley SD intake or Trick Flow intake. I want to use the Trick Flow intake but hood clearance will determine what's finally used. I don't have any HP/torque numbers. Engine goes on the dyno Monday
Re: Fuel injection question [Re: Blown_Hemi] #2592193
12/15/18 03:34 AM
12/15/18 03:34 AM
AndyF Online content
AndyF  Online Content
If you get the Super Sniper you can get rid of the fuel pressure gauges. The Super Sniper can data log up to three pressure sensors so you can track fuel pressure and oil pressure with the Sniper.
I'd also recommend adding the Hyperspark distributor with the Sniper. That way you can control the ignition timing from the Sniper. Check out the Sniper + Hyperspark article in the Jan issue of Hot Rod.
Re: Fuel injection question [Re: AndyF] #2592244
12/15/18 11:05 AM
12/15/18 11:05 AM
Thanks guys for all the info. I will look into the Hyperspark. I had a MSD system but the boxes kept crapping out. Went with a DUI distributor and really like it.
Re: Fuel injection question [Re: Blown_Hemi] #2592252
12/15/18 11:46 AM
12/15/18 11:46 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Although Holley makes a “Coil near Plug” ignition kit, theTBI like Sniper cannot run it?
https://www.hotrod.com/articles/test-holleys-new-sniper-efi/
Sample quote
The Sniper EFI unit will control your ignition system, with plug-ins available for HEI and most aftermarket distributors. You can also run it without ignition control.
End quote
