Correct studs for 8 3/4 axle housing? #2586299
12/02/18 09:02 PM
12/02/18 09:02 PM
Citrus Heights, CA
69_Swinger Offline OP
Citrus Heights, CA
I bought a stripped 8 3/4 rearend for an a-body, and the PO had removed all the studs (pressed in on the ends of the axle tubes, and where the 3rd member mounts in). I had heard that Ford 9" was the same. I was thinking of going with either of these:
https://www.summitracing.com/parts/aaf-all72040/overview/
https://www.summitracing.com/parts/axe-bs9500/overview/
Will these work? Are they also correct for the axle tube ends?
Thanks!
67 Valiant /6 2-door (Father/Daughter project)
Re: Correct studs for 8 3/4 axle housing? [Re: 69_Swinger] #2586303
12/02/18 09:04 PM
12/02/18 09:04 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Doctor Diff has some if you want to check with him? www.doctordiff.com
Re: Correct studs for 8 3/4 axle housing? [Re: 69_Swinger] #2586309
12/02/18 09:17 PM
12/02/18 09:17 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
The correct axle end studs use a partial circle flange, different then the carrier studs.
Re: Correct studs for 8 3/4 axle housing? [Re: 69_Swinger] #2586335
12/02/18 09:59 PM
12/02/18 09:59 PM
Citrus Heights, CA
Citrus Heights, CA
Just ordered all of it from Dr. Diff. Thanks!
Re: Correct studs for 8 3/4 axle housing? [Re: 69_Swinger] #2586594
12/03/18 02:07 PM
12/03/18 02:07 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Hate to jump in on the thread like this but I am in a similar boat. I have an 8-3/4 that has no studs where the center section goes. Where can I find these studs? TIA
Re: Correct studs for 8 3/4 axle housing? [Re: Rob C] #2586606
12/03/18 02:31 PM
12/03/18 02:31 PM
moparx Offline
moparx  Offline
as said : DR DIFF. up great guy to deal with !
beer
Re: Correct studs for 8 3/4 axle housing? [Re: 69_Swinger] #2586654
12/03/18 03:52 PM
12/03/18 03:52 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Thank you moparx
